White spirit as a c...
[Closed] White spirit as a chain cleaner
As above, does anyone use white spirit to clean chains? Any reason why it shouldnt be used?
Posted : 13/12/2012 4:37 pm
i do - works well.
Posted : 13/12/2012 4:44 pm
Diesel is better, and probably cheaper.
Posted : 13/12/2012 4:45 pm
I use turps substitute before dunking it in putoline wax.
Do it in a jar, it's nasty for the environment so best kept contained, the gunk settles out so you can decant to a fresh jam jar and keep using it indefinately.
Pour the dregs into a big bottle and take to the recycling center allong with all your old engine oils, brake fluids etc.
Posted : 13/12/2012 4:48 pm
I used white spirit to clean my chain - got a jam jar full which the chain goes in and is given a shake and left overnight. All the dirt sinks to the bottom.
Then degrease the chain with Jizer.
Posted : 13/12/2012 5:34 pm
Works fine but paraffin and diesel are both cheaper.
Posted : 13/12/2012 5:37 pm
a chap i used to work with cleaned his chain with thinners, worked well, but he threw the oily rags in the bin and somebody then threw a fag end in, result big fire, and he also tiped the residue down the drain outside, large flames as somebody dropped a fag down drain.Thiners floats on water,in the drain.
Just be careful what you do with the residue
use swarfega oil and dirt remover about 8 quid a gallon form b and q
Posted : 13/12/2012 5:51 pm
Ta - learnt something simple I didn't know ....
Have been doing it in a tray and it was a right mucky mess and needed throwing away each time.
Posted : 13/12/2012 6:35 pm
I use aviation fuel for free which is basically kerosene, brings chains up nicely. Have also used white spirit which was fine too.
Posted : 13/12/2012 6:43 pm
Useful tip bigbloke. Now where can I find some Aviation Fuel for free? ๐Ÿ˜€
Posted : 13/12/2012 7:02 pm
Yes should have stated kerosene is heating oil/paraffin , available commonly, cheaper than diesel but obviously not free though ๐Ÿ˜• ๐Ÿ˜ณ
Posted : 13/12/2012 7:07 pm
Been using white spirit for years now being a decorator :D...white spirit is expensive though ๐Ÿ™
Posted : 13/12/2012 7:09 pm
White spirit user here.
4 litre container of white spirit from a DIY store.
Clean your parts - pour your dirty ws into another 4/5 litre container (empty windscreen wash containers are a good source)
Dirt settles down to the bottom in the used ws - after a day or so. When you start to run short of the fresh clean ws carefully pour off the "clean" ws from the dirty container back into the original clean container - big funnel is good for this.
Easy get 2 years out of a 4L container like this.
Posted : 13/12/2012 7:12 pm
Often use a coffee filter for pouring ws back into original jar to stop dirt getting through. Something I read here some time ago.
Posted : 13/12/2012 7:32 pm
good tip - I like that idea.
Posted : 13/12/2012 7:33 pm
Yip, me too, Mobil jet A1 for all your chain cleaning needs!.
Posted : 13/12/2012 7:41 pm
WD40 and GT85 are 90% white spirit anyway so yeah knock yourself out.
Posted : 13/12/2012 9:31 pm
Old 2ltr milk container filled with a couple if inches of White Spirit, chain in, shake like buggery, leave for 10 mins. Pour into container 'b' with filter on top, jobs a good 'un.
Posted : 13/12/2012 10:02 pm
JIZER
Posted : 14/12/2012 12:03 am
Yep, started using white spirit here, works pretty well. I like the coffee filter idea aswell.
Posted : 14/12/2012 12:06 am
The problem with jizzer, gunk, etc is they're surfactant based. So you then have to wash with a lot of water otherwise they'll turn whatever chain lube you use to an emulsion which then washes out. Whereas any residual white spirit will evoporate, and anything left after that is just oil anyway.
Posted : 14/12/2012 9:44 am
Dishwasher...end of !
Posted : 14/12/2012 9:57 am
"Jizzer" is good for cleaning chains/gears and stuff on your bike when your washing it. Give it a good rinse off and relube for next time when done. I blow water dispursant though the chain when done as it strips all the old grease out.
I'd use parafin for when everythings apart.
If you have a compressor, clutch/brake cleaning fluid (available from Auto factors) or methanol (Available from mentalists) in a parafin gun for blasting the dirt out of things is brilliant (and very satisfying), just don't smoke at the same time....
Posted : 14/12/2012 10:08 am
Blimey! Do you lot do this after every ride? I just spray it with a hose, wipe it with a rag, lube and leave
Posted : 14/12/2012 10:11 am
Just used a Park chain cleaner thingy for the 1st time and I'm sold. Always used to use a degreaser (free from work) but had to take the chain off every time. Now gone SRAM 10sp chain with lock-link so don't want to be faffing with getting that off..
Chain cleaner works brilliant (with free degreaser in), blow chain dry gently with air-line, oil. Took me 5mins and have a shiny, oiled chain again ๐Ÿ™‚
Posted : 14/12/2012 10:15 am
You clean it after every ride? You obviously have more spare time than me.
Takes about 3 months in normal mud to get putoline off.
Posted : 14/12/2012 10:30 am
