White Lightning Cle...
[Closed] White Lightning Clean Ride
This chain lube comes highly recommended both here and on Amazon, but I'm finding it a royal pain to use. I shake it well but as soon as I start to apply, the tip clogs and I have to shake again.
Any tips?
Posted : 03/01/2019 4:16 am
I've never used it, but do you keep it in a shed/garage? Maybe try keeping it in the house, see if it keeps it a little less viscous?
Just a thought.
Posted : 03/01/2019 9:23 am
^^ Yeah, is it possible it needs to be kept fairly warm before use as nobeer alludes to?
Posted : 03/01/2019 9:39 am
A fantastic product I thoroughly recommend never had an issue with it hmm
Posted : 03/01/2019 9:47 am
I've used it (and like it) but only as a summer lube - this time of year I'd switch to something with a bit more wet weather resistance. It's not as bad as RnR Extreme for clogging in the cold but that could be a part of it.
Try Epic Ride instead.....I find it great for all conditions and it doesn't clog, even though stored in a cold garage.
Posted : 03/01/2019 9:01 pm
Get exactly the same with mine, just open the hole a little bit.
Posted : 04/01/2019 8:42 am
It’s not as bad as RnR Extreme for clogging in the cold but that could be a part of it.
Eh? I've been using RnR for what must be about 5 or 6 years now, never had that.
Posted : 04/01/2019 9:11 am
I used to use the White Lightning stuff, then went to RnR blue (much better) and now W&S no. 3 (better again). Wholly subjective depending on the ground conditions upon which you ride though.
Posted : 04/01/2019 9:59 am
is that the summer lube one? i found the same thing that the nozzle clogged really easily till i opened it up a bit, bought epic ride since then - its great
Posted : 04/01/2019 12:28 pm
Eh? I’ve been using RnR for what must be about 5 or 6 years now, never had that.
I found that RnR blue would solidify in the bottle when it got cold - keeping it in the house helped but lubing a cold chain on a cold day could still make the nozzle clog up. Once on the chain it was good stuff.
Posted : 04/01/2019 12:41 pm
Used white lightning but found the wax really built up on the jockey wheels, after several different try out settled on the W&S no3 which is amazing and really does clean y=the chain! Peatys has bought them out now so just restocked with their lube. Fingers crossed it is a good.
Posted : 04/01/2019 11:26 pm
Genuinely never had that thepurist, I have a couple of bottles inbthe garage right now, it's about 4deg outside, and I could go use them right now.
Posted : 05/01/2019 12:01 am
Personally I use wet ride all year.
It’s easy to apply and also easy to remove. I don’t fully understand the concept of wax lube, I like to see oil! Perhaps I need educating as to the benefits.
Posted : 05/01/2019 7:46 am
Never used Clean Ride but I use White Lightening Epic a lot and find it excellent all year round but have just bought a bulk of RnR Gold so will be using that for the foreseeable. I keep it in the house FWIW.
Posted : 05/01/2019 11:03 am
Be interested to hear how you get on with your change blazin-saddles as I did the same as you but prefer epic
Posted : 05/01/2019 1:37 pm
