white industries si...
[Closed] white industries singlespeed freewheel
 cmyk
[#299292]
does anyone have any experience of these?
how long do they last between services?
i have always thought that i was better off buying ten cheapo freewheels for that price-but having destroyed two in the past month riding to work in the crappy conditions, i'm not so sure!
many thanks.
Posted : 12/02/2009 3:14 pm
The WI ones look good and are rebuildable but they still aren't as reliable as a standard cassette rear wheel if my mates' experiences are anything to go by.
Unless you really can't bear the aesthetics of running a rear wheel with a sprocket and spacers then I just don't see any advantage or point in running a SS specific (Screw on type at least, not the cassette type SS specific ones) rear wheel.
Posted : 12/02/2009 3:19 pm
I find clubbers comment interesting.I've suffered the same as cmyk and am now wondering whether to get a WI freewheel or get a new rear wheel and spacers/sproket set up.
Preferences/Pros/Cons????
Posted : 12/02/2009 3:32 pm
I thought the same about cheapo freewheels; my first Shimano freewheel lasted ages, the second died really quickly so I bought a WI and so far it's been flawless. Just got back from a ride on my SS actually.
It's still fairly new (about 3-4 months old) and it hasn't needed a service yet.
Posted : 12/02/2009 3:34 pm
I've had mine about 18 months. Commuting and easy to mid level offroading. I'm 105kg so can exert some force through drive train. Haven't touched my WI apart from a wipe off now and again.
I'd be happy to look at one again depending on cost. With current £ 2 $ exchange could be Very expensive.
How about the Hope SS specific hub? The freehub on these should be rebuildable too.
Posted : 12/02/2009 3:42 pm
 Del
been running one for a couple of years. used at least once a week, if not three times, and that once a week is probably circa 1200m rise and fall and around 25-30k. have replaced one bearing ( tenner posted from sideways cycles, rang after lunch, arrived next day ). i got mine in the US cheap, but Charlie has them for about 60 quid i think? and i'd buy again at that price.
Posted : 12/02/2009 4:00 pm
Very reliable compared to the shimano or acs freewheels in my experience. Nice smooth click too.
A year or so ago they could be had from the US for around £45. As above, probably a lot more at the current exchange rate.
Servicing is pretty easy, but new bearings aren't particularly cheap. I actually wore out the teeth on my 1st one in about 18 months use. I decided it was better/cheaper to get a complete new one rather than the 'Trigger's brush' type approach of new sprocket and bearing.
Posted : 12/02/2009 4:01 pm
 Del
oh! and if you have a wheel suitable for a screw on freewheel they're worth it, yes. if building from scratch, maybe not, but a mate tried a 'wide based steel cog in steel' to fit a freehub, and he got through that really quite quickly indeed.
Posted : 12/02/2009 4:03 pm
I stand corrected - only a tenner for the bearing according to Del
 cmyk
hmm, thanks everyone.
think i might go for it and get one.
charlie the bikemonger seems to be the cheapest.
Posted : 12/02/2009 4:11 pm
Had mine for a couple of years. They need servicing though.
Posted : 12/02/2009 4:30 pm
Now 2 winters of no service and still seems OK. Pretty well used, solo races, through above hub level water a couple of times, that sort of thing.
I think you would have to get a highish end freehub to match it for reliability, e.g. hope or xt.
basic revolver SS hub + WI freewheel is about £120
regular hope rear hub plus a cog and spacers is about £140
Not much to choose if starting from blank but as you already have a wheel, I say get one.
Posted : 12/02/2009 4:31 pm
Mr C.T. Bikemonger does not appear to have any 16t WIs - neither does Tim Sideways. 🙁
Posted : 12/02/2009 4:51 pm
17t ones have different bearings which are more reliable. Or that is what I've been told, no direct experience. Anyway I run 17/32
Posted : 12/02/2009 4:55 pm
 Del
send him an email. he might find one down the back of the sofa.
Posted : 12/02/2009 5:15 pm
