which tire manomete...
[Closed] which tire manometer should i get ?
 jeb
Posted : 24/09/2019 11:39 am
You mean pressure gauge, right?
Posted : 24/09/2019 11:53 am
I have learned a new word. thanks.
I got a Topeak D2 recently and it seems to do a good job and showed that my track and shock pumps were both off by varying amounts. It claims to work on shocks as well but in practice I found that even the small bit of air that was released from the rear shock when removing the gauge meant a loss of about 5-10psi so I just use it for the tyres and fork.
Posted : 24/09/2019 12:08 pm
I've just got the topeak D2 for cross - £20. Works great but I've had a couple of gauges and the proof of the pudding is how well they last, they seem to deteriorate IME, I think because sealant from tubeless tyres can contaminate them. This one is well reviewed, though.
Pressure gauges on both my floor pumps are completely useless up to around 30psi - they seem to wake up after that so are OK for getting a measurement on road tyres at 90psi or whatever.
Posted : 24/09/2019 12:20 pm
D2s seem to over-read by a couple of PSi. Think the STW test found this and mine seems to do similar
Posted : 24/09/2019 12:27 pm
The blue Schwalbe ones.
Cheap, easy to use and read, tough, light and the first battery on mine lasted 7 years
Posted : 24/09/2019 2:42 pm
Manometer do doooo da doo do
Posted : 24/09/2019 2:43 pm
