Hello,
Which seat clamp QR would people recommend to be relatively easy to close but give a firm clamping action?
My friend is having trouble with slippage, she is very light so it is not a weight thing. The bike is an on-one inbred with Thomson seat post, is that a known bad combination? The current QR is an Azonic one I think. I like my Salsa Flip lock so that is my starting point for a recommendation.
A bolted option or dropper are not options.
Been pleased with my Hope, it's not a trial of strength to get it tight, that's on a Pace RC129 with a Thomson post.
Salsa
Salsa Fliplock
Using some carbon paste like Finish Line Fiber Grip might be a better and cheaper solution though.
Salsa + ๐
Another Salsa vote..........better than anything else I've tried ๐
Flip locks are about as good as they get ime, the opposite to my experience with a Hope QR. But check your seat post / tube tolerances are close if a light rider is causing slippage since pretty much any qr should hold if done up averagely tight - it's usually how stiff the lever is/becomes to close at a good tension that's the problem. A steel frame and a thomson should be good, generally thomsons seem a closer fit than many posts.
check the inside od the frame is clean and smooth. a blast of gt85 and a quick rub with some scotchbright/wet and dry should do the trick. if there are any solid lumps then your LBS should be able to ream the tube.
Clamps- salsa, hope, etc all good. Posts- Thomson are normally about the best fitting, double its the right size.
Check the frame, get a solid clamp. she should be right.
Thus but I'd replace the GT85 with IPA.
Another vote for the salsa. Although I tent to have Hope to match other bits and they are fine. Just make sure you have a nicel prepped seat tube and post, a LITTLE bit of assembly grit paste or anti-seize (I use shimano as I know it's carbon and aluminium safe) and don't overtighten.
Good confirmation and consensus ๐ matches my experience.
I think the checks mentioned are an important part of this. Thanks all.
Tune Wurger.
Nothing else comes close.
Chromag are way better than the Salsa ones - no issues getting clogged in mud if you're using it regularly on a ride. Costly and can be hard to find though.
That tune one looks interesting, they're quite rated, but look a bit wrong ๐
Salsa +1
And IME, Thomson -1, the two I've had had a habit of slipping
Another vote for chromag. Excellent piece of kit
Chromag are great, much better than Hope and more positive action than Salsa. Very industrial looking but in a good way.
Salsa, Salsa, Salsa! (Fliplock).
A friend was suffering the same with an Azonic on an On-One, Hope post though. A Hope clamp sorted it for him.... And he's a phat phucker too.....
Chromag. The only reason I don't use it any more is that my latest frame has a built in seat clamp. It was operated a lot for about 4 years and still looks and works as well as the day I bought it.
never used a chromag but they do look good.
Been using Hope QR seat clamps for years and never had a problem with them slipping yet, and I'm a right chunker.
From personal experience, I've found [url= http://www.dkg-cnc.com/sizing.html ]DKG[/url] who designed and made the original Salsa clamp and [url= http://shore-lines.co.uk/Seatclamps?product_id=181 ]Chromag [/url] to be the best.
Salsa
chromag by yards
Just a thought.There is another possibility that no one has mentioned.Have you checked the seatpost is the correct size??
The best I've used are Hope,,having said that,I've never tried Salsa or Chromag
Syntace Superlock2.
Holds my 13 stone up and can close it with the tip of my index finger!
+1 for degrease and carbon paste.
The only choice here is Chromag!
[img] https://encrypted-tbn2.gstatic.com/images?q=tbn:ANd9GcQuD7O-9nZ1CJ-N1t3czU5r9woW20kqM-HHcykclbDTaL5ltq3974PnwALJ [/img]
Salsa.
I've used salsa, hope and various others over the years. By far the best (brass insert, decent lever shape) is the chromag, which blew the rest away. Well worth the cash.
Another Chromag vote
Standard clamp on my genesis was crap, 27.2 post, moving all the time. Changed to hope, all fine!
Salsa here.
Frame is 29.6 (Niner, steel), & kept slipping with a 30mm Hope clamp.
Salsa one never moves.
Ah OK, I think I have spotted the issue potentially....
The On-One website lists the seatclamp size as 29.8:
[url= http://www.on-one.co.uk/i/q/FROOVDO126/on_one_inbred_26er_vertical_dropout ]On-One seatclamp sizing[/url]
but that isn't a very common size so I suspect it has a 30.0mm on it.
Will a 30.0 Salsa do a better job or should I seek out a 29.8mm in an alternative brand?
Surprise, surprise On-One make something in the right size and a bit fliplock esque:
[url= http://www.on-one.co.uk/i/q/SCOO6061T6/on_one_tech_series_cnc_quick_release_seatclamp ]On One CNC seat QR[/url]
salsa. i broke a hope trying to get it tight enough
30.0 chromag was perfect on my 29.8 on one, and my 29.8 dialled.
Replaced the cheap on-one qr that used to slip and was hard to close tightly after a while.
Buy cheap, buy twice!
