Which Joe Blow?
[Closed] Which Joe Blow?
[#6086131]
I currently have the cheapest Joe Blow track pump, which is about 5 years old. It's started blowing the air out of the schrader side when attached to a presta valve and replacing the available head parts hasn't fixed it. A new head is about £16 so I may just replace the lot.
Question is which one to go for? It'll be used for mtb and road tyres.
Posted : 02/04/2014 12:41 pm
In the finest stw tradition, none of 'em. They're nicely made but not amazing performers- the Mountain is good but not for road.
I like my Air Towers, they're cheap and nasty feeling but they work really, really well- shift tons of air but also will do 120psi, a great balance. Miles better than my old Joe Blow. But probably there are better options.
Posted : 02/04/2014 12:43 pm
yes, better options available.
I have the mountain but the valve drops a fair bit of air when putting on and off, my old SKS was much better.
Posted : 02/04/2014 12:46 pm
I assume when you say Air Tower you mean the Blackburn one?
Posted : 02/04/2014 1:11 pm
I got a cheap as chips Airwave Storm. [url= http://www.chainreactioncycles.com/airwave-storm-track-pump/rp-prod47804 ]Here[/url] it's great.
Posted : 02/04/2014 1:18 pm
As much as I like my several years old Air Tower 5 I wouldn't really recommend as you need to replace the whole head every time the rubber seal wears too much to grip. I'll be getting a Lezyne next time...
Posted : 02/04/2014 1:41 pm
Having had my Joe Blow for something like 10 years, with occasional refurbs, I thinks there great but will seriously consider something more substantial when I come to replace it. It's one of those over looked tools that you just rely on to work & will use for years and years with little or no maintenance (luckily no one trying to change valves standards ATM). I'm impressed with the lezyne metal floor pumps & they will be seriously considered when the time comes, as my JB is showing it's age. There seriously quite expensive but if they last, that's well worth the investment.
Posted : 02/04/2014 1:52 pm
Love my Lezyne, had it a few years and its been fine. Had to replace the gauge when I broke it and Lezyne sent me a replacement for free, also bought the 90 degree push on head adaptor and they are beautifully made things.
Posted : 02/04/2014 1:53 pm
 kcal
Had my Joe Blow Sport PX (or some such) double headed track pump; still going easily after 10-12 years, replaced some of the head valves and seals as well, or at least cleaned out the chamber, good as new..
Posted : 02/04/2014 1:54 pm
Thanks for the suggestions, I've gone for a Joe Blow Sprint @ £36 which I thought was pretty resonable.
Posted : 02/04/2014 2:22 pm
Seriously lads?
Silica Superpista. The last track pump you will ever buy.
End of thread.
Posted : 02/04/2014 2:34 pm
Thanks for the suggestions I've ignored them totally and I've gone for a Joe Blow Sprint @ £36 which I thought was pretty resonable.
FTFY 😉
FWIW, I now use the basic Spesh Air Tool Sport (IIRC), find it lasts far longer than Joe Blows I used to use, in fact it's what we used in the workshop at the LBS as they lasted so well.
Posted : 02/04/2014 2:39 pm
njee20 - Member
FTFY 😉
Very true 😆
But with about 5 different suggestions in 10 posts I went with what I know, hopefully it'll be ok.
Posted : 02/04/2014 3:03 pm
