which gripshift wor...
[Closed] which gripshift works with shimano and sram x7 and x9 rear machs?
5 Users
 ton
anyone know or have some for sale.
Posted : 24/02/2012 8:50 pm
X7 and x9 use a different cable ratio from Shimano there's no one shifter that does what you want.
The Shimano compatible ones are coded SRT IIRC.
what deraileur do you need to work with and I can see what I've got.
Posted : 24/02/2012 9:00 pm
 ton
i have a deore and a x9 rear mech. i can swap and use either.
Posted : 24/02/2012 9:05 pm
 ton
the info off crc's sales bumf says it will work with sram and shimano.
http://www.chainreactioncycles.com/Models.aspx?ModelID=78434
Posted : 24/02/2012 9:09 pm
Can't see how that Attack can work with both. I just bought some and it works with Shimano. You would have to change the cable pull to make it work with SRAM and I don't know how you would do that.
Other gripshifts (X9,X0) only with with SRAM mechs, but watch out the new 10 speed SRAM mechs (anything marked Exact Actuation) are slightly different and don't work with 9 speed shifters (been there, done that).
Posted : 24/02/2012 9:28 pm
Sram X series gripshifters will only work with Sram rear mechs.
Sram Attack gripshifters will only work with Shimano rear mechs
Either type will work with Sram or Shimano front mechs(Im using XO gripshifters with a Shimano LX front mech and XO rear mech)
Posted : 24/02/2012 9:52 pm
attack shifters have a 2:1 ratio. this is compatible with shimano and old as the hills sram rear mechs. it will not work with an x9 rear mech. for that you need an 'x' range shifter. this only applies to rear mechs. as stated above, front mech/lh shifters are interchangable.
Posted : 24/02/2012 10:00 pm
 ton
cheers guys
Posted : 24/02/2012 10:11 pm
