Which goggles?
[Closed] Which goggles?
[#3886507]
Recommend me some for my first set please.
Posted : 18/04/2012 9:12 pm
Oakley O-frame.
Got about 4/5 pairs that I use for motocross, cannot fault them. Pattern lenses and tear offs are easily available and cheap.
Posted : 18/04/2012 9:16 pm
Oakley crowbar. Funky.
Posted : 18/04/2012 9:18 pm
O-frames or Crowbars. Cheap and they make instant sense the moment you try to get spare lens' for an alternative brand
Posted : 18/04/2012 9:23 pm
I've got some Crowbar MX and they're great! They come with a set of laminated tear offs too
Posted : 18/04/2012 9:27 pm
Ones that fit your fullface helmet....comfortably
Posted : 18/04/2012 10:04 pm
 GW
Never Oakleys unless you actually like seeing through steamed up plastic.
new original and "patern" lenses (and tear offs) are easily available cheap online for most goggles
Posted : 18/04/2012 10:09 pm
Beer goggles. Never had a bad night with them.
Posted : 18/04/2012 10:22 pm
 Taff
I found Oakleys steamed up quite a bit. I used smith warp stars and found them brilliant
not everyone's as sweaty as you old man 😉
Posted : 18/04/2012 10:24 pm
I quite like Spy's
Posted : 18/04/2012 10:35 pm
Having had oakley, dragon & fox...
Fox Main - great fit, cheap spares & match my lid 😉
Posted : 18/04/2012 10:37 pm
 gazc
Always used o-frames - cheap, very easy to get spare lenses / tearoffs either Oakley or copies. As for steaming up just take the foam off the vents and give them a swing around your head before a run (assuming u using for dh) that helps prevent/reduce it
Posted : 19/04/2012 10:47 am
 IA
This. Steaming up only been a problem in the wet, I don't bother to take the foam off though.
Posted : 19/04/2012 10:57 am
Oakley Crowbar MX for me - but as above, make sure they fit your helmet
Posted : 19/04/2012 11:04 am
Ones that fit your helmet/face. Quite a lot of goggs sit on the bridge of my nose, which is distracting and can make it run 😕
I've know people who don't even own Oakleys recommend them! Probly cos they're "the brand" to have?
I was recommended double glazed ski goggles to combat misting and bought a pair of these:
http://www.amazon.co.uk/DOUBLE-WEATHER-GOGGLES-MERCURY-LENSES/dp/B001NIC9V6
They happen to fit my face nicely & don't mist easily (but it can be acheived). The strap has a clip so you don't have to slide them up your helmet to get them off - meaning they don't push loads of crap into your eyes when you slide them down again.
Posted : 19/04/2012 11:08 am
Can't really go wrong with O Frame Mxs IMO. Spy Klutch also most excellent.
Posted : 19/04/2012 11:11 am
I prefer my Giros to my Fox but cant get replacement lenses for the Giros.
Posted : 19/04/2012 11:26 am
 loum
speedo
Posted : 19/04/2012 11:46 am
Cheers everyone - some good options to check out there.
They're not actually for 'DH' tho although the intended use if for descents if that makes sense! Cheers again
Posted : 22/04/2012 8:08 pm
