Which forks for a M...
[Closed] Which forks for a Maverick ML75 (sorry!)
[#1698573]
I'm very tempted to build up a ML75 given they seem quite a good deal these days. I've narrowed forks down to either a dt swiss exc at 130mm or a fox float rl at either the 120 or 140mm lengths. Is the 140 too long?
I know Maverick say 150mm is fine but that with their own forks which I think are short axle to crown.
Any experiences much appreciated.
Posted : 12/06/2010 5:13 pm
I ran pikes at 140mm on mine followed by 150mm fighters, got Ducs on my ML8 and they are far better than the nay sayers give them crdit for. I liked adjustable forks for mixing and matching
Posted : 12/06/2010 5:27 pm
Isn't it sacrilige(sic?) to run one without maverick forks? Like a pace running anything other than pace forks (apart from less than 3 year old ones).
Posted : 12/06/2010 5:41 pm
the ducs do match the rear suspension well but............i think for me foxs/pike/pacess slighlty stiffer and more small bump sensitive
In all honesty no compliants at all with any
Posted : 12/06/2010 5:44 pm
SC32's? I've just picked a brand new set from a guy with a few of them for sale for £200 & they are very plush & lighter than the DUC.
Posted : 12/06/2010 6:30 pm
Duc32, as Swift sez - anything else probably contravenes some law or other!
Posted : 12/06/2010 7:26 pm
7/5 is designed for SC's, is'nt it? Float 140's on mine fwiw though.
Posted : 12/06/2010 7:30 pm
Cheers guys, I'm afraid I'm not tempted toward the Maverick forks, I owned a set of SC32, it's not that they were bad but I couldn't get on with the twisty nature of them. So it's more about if a fox 120 or 140 is more suitable.
Vinneyeh how does it handle going up with the 140s?
Posted : 12/06/2010 8:14 pm
All this really reminds me how much I want a maverick. Anyone got one, and what cool name do you have?
Posted : 12/06/2010 8:16 pm
my frame is Bingo
xavier was the one before....now passed on
Posted : 12/06/2010 8:24 pm
why the hell do u say sorry in your title ? ain't that what a mountain bike forums for asking questions about bikes ha ha
Posted : 12/06/2010 8:53 pm
Too right jamesy, but gven the attitude of some on here I can understand the apprehension.
Posted : 12/06/2010 9:04 pm
'sorry' guys 😉 I had a feeling 'what fork for' was just a level above 'what tyre for'. I appreciate the advice, I'm definitely edging closer to the Maverick.
Posted : 12/06/2010 9:40 pm
So far on my Maverick I've ridden DUCs (the steering was too floppy by half), SC32s (OK, but not all that on this frame), Rebas (fantastic but too little travel) and U-turn Revelations (just right).
Avoid the Mav forks on it, in my opinion. The DUCs never felt right at all - seriously avoid them. I'd go for something with 130mm ish of travel - any more than that and you'll have to ride off the front of it the whole time - which is fun, but not ideal for climbs.
Posted : 12/06/2010 10:44 pm
 mboy
On an ML7/5 I'd run a 120-130mm travel fork out of choice. Anything longer will make the front end feel quite slack unless you run a lot of sag. Besides, it was designed to be run with a fork of approximately 5" of travel anyway.
You could get away with a DUC32 by running it with quite a bit of extra oil in the air spring, so that the spring rate ramps up drastically, so that you would effectively be using as much as 50-55mm of travel as sag (so it would ride at the same height as most 130mm forks), whereas you would normally be running approx 35-40mm of sag. A 140mm Fox will have the same axle to crown height as the 150mm DUC32 though, so I'd steer clear of a 140mm fox personally, unless it could be spaced down to 125/130mm of travel internally like the Rockshox Revelations can.
Anyway, got a Durance myself... It's called "Medusa", and has a DUC32 fitted. The Durance was designed to be used with the DUC from the off, so the BB is slightly lower, and the head angle tweaked to make the bike feel more stable with the longer fork fitted. And it ROCKS! I had an ML7 before, and the Durance geometry is a good step in the right direction, as I felt a bit too much "on" the bike with the ML7, whereas with the Durance I feel much more "in" it, and it handles much better as a result.
Posted : 13/06/2010 12:31 am
Really ugly ones.
Posted : 13/06/2010 5:30 am
mboy may well be (probably is) right. I dithered about forks, in the end stuck on the Floats in the knowledge they could be spaced down to 120.
I've not had XXX for long (too embarrassed by the name- a welder that can't spell, d'oh!) and she's only had runs on the South Downs and bits of the North Downs, and none of the riding has been what I'd call technical so can't comment too much on the handling with the forks, although the bike does seem to find good traction on one particularly dry loose and gravelly climb where the hardtail (and I) really struggle.
Posted : 13/06/2010 10:39 am
Come on, how bad can it be? Name....
Posted : 13/06/2010 10:57 am
Intresting about the DUCs, they are odd there are times when i agree when the steering is floppy, e.g high speed left hand turns but other times when they are great trails with lots of roots and dips, they are almost untoiceable....maybe i am concentrating more but the forks feel good..............agree with the 130mm mark it is better to climb with, saying that I was happy in glentress on the climbs with 140mm pikes
BUT
the ML8 is a better climber 😀
Posted : 13/06/2010 11:23 am
my ML8 is called Wesley 😕
Posted : 13/06/2010 11:48 am
I'm with Grezelda (sic) 😳
Posted : 13/06/2010 12:19 pm
 Sven
Trailseeker, would you mind sharing where you got SC32s from at that price? Thanks, Sven
Posted : 13/06/2010 1:55 pm
I'd look at adapting a lefty if it was a durance. It might make your eyes water to look at it, but it could be a hell of a combination to ride.
Posted : 13/06/2010 5:24 pm
You can get lefty's for standard headtubes now. Still would be wrong on a mav though.
Posted : 13/06/2010 6:27 pm
You don't need to go through all that palaver with a DUC32 - you can simply use a spacer to reduce the travel and ride height. I run and ML7 as a race bike - 'Ego', he's called, amusingly - and run DUC32s spaced down to 135mm of travel. At 150mm they were too tall for the frame and screwed up the geometry, 15mm less and they're about right for me.
I also had issues with the medium ML7 trying to fit set of Revelations, the fork adjusters fouled the downtube on full lock. Don't know if that's the case with the 7.5, but it's worth being aware that it may be an issue. Tim at Sideways is ace for Maverick advice / parts etc btw.
Posted : 13/06/2010 10:06 pm
 mboy
What BadlyWiredDog says... V good idea actually!
Oh, and for some cool names, see the [url= http://forums.mtbr.com/showthread.php?t=569647 ]MTBR thread[/url] that I started a while back enticing owners to list their bikes names up there...
Feel free to post yours on there if you haven't already!
Posted : 13/06/2010 11:32 pm
Sven - give me your email address & I'll foward the details
Posted : 13/06/2010 11:40 pm
 Sven
That would be great, here is the address:
svenDOTkoehlerATgmxDOTnet
thanks
Posted : 14/06/2010 2:35 pm
I run DUC32s on my ML75 (Baldrick!!) and it is fine.
Am looking to change it for an ML8 if anyone is interested. Has done less than 500miles so is like new!
Posted : 19/06/2010 11:03 pm
Jeeeezus - I've got a bike called Xavier !!!! 😯 😆
Posted : 19/06/2010 11:43 pm
Pike top caps catche the downtube.possibly only the u-turn side though.I fitted a spacer under the crown and seem to remember the bike feeling best at around 125-130mm.
a well centred ht2 alloy spacer can do the trick under the crown race if you cant get a hold of a +5mm race to fit your existing headset.theres more than enough of the correct diameter of steerer to hold the race even after fitting a 2.5mm spacer so dont worry about running out of the correct diameter for the race to bite on to.
Posted : 20/06/2010 1:53 am
Hey Woody how is xavier going on..............???
Posted : 20/06/2010 8:45 am
All ready to go as soon as I get the DUC's. I thought about fitting a pair of Nixons but decided to wait and get the cabling spot-on, which is unusual for me as I tend to throw anything onto frames just to get a feel for how it rides.
Can't wait to get out on it. 😆
Posted : 20/06/2010 9:21 am
great....let me know how it all goes........cheers
Posted : 20/06/2010 9:47 am
Hey chillidave,
I myself ride a Maverick ML75 named "Gypsy" (though I call her "Pikey") with an SC32 Fork.
I can't recommend this frame and the overall design concept enough.
Having been fortunate enough to own a few Cannondales (such as a Gemini with a Manitou Sherman Fork & an F1000 with the Titanium Lefty) I too shared your concerns regarding the fork issues but can tell you that I have never ever felt any issues with them regards stiffness and tracking etc.
In fact I highly rate the SC32's for ease of tune-ability and maintenance - theyre an absolute breeze.
Check out some of the Q&A's on the maverick website as they make a highly valid point regards the flex issue which concerns you.
Hope this helps.
http://www.maverickbike.com/main/do/FAQs
Posted : 17/08/2010 8:21 pm
