it's a pawl version, not star ratchet. bolt through, boost 148mm Trying to identify it so I can try to get hold of a parts diagram
thanks
370?
there's probably a code number printed on it, often underneath the disc carrier
I assume that'll translate into a model
(edit):
My 2018 Enduro has 350 hubs so maybe it's one of those?
If it is and you want to change the bearings.... Good luck. It has a lockring which needs removing with a £60 tool, three mates and a scaffold pole (or at least that's what it looks like).
... Thats the wheel bearings not the freehub bearings.
The freehub just pops off.
They normally come with Bontrager wheels not DT Swiss
Which model fuel?
Your local Trek dealer will be able to pull up the tech info for the wheels which, unless you have XXX models, will be Bontrager hubs.
