I have a new dh bike with avid elixir 7 brakes but fancy putting them on trail bike (cause I need new brakes on it). What brakes would you lot recommend for dh (i am thinking especially for the week in the alps)?
xtr m970's here>>>>>>>>
http://singletrackworld.com/forum/topic/ibis-sl-frame-xtr-2011-fox-36-industry-9-and-loads-of-other-parts
Hope V2's
Hope if you want to support British engineering.
Saint's in you want to stop quickly.
Saint's need setting up properly tho - need a syringe to basically pressurise the system slightly from the calliper end otherwise there is a hideous amount of lever travel.
Not XT, they are shite, my brother has some and they have never worked properly for more than 10 minutes.
Hope would be my choice, best brakes I have ever used.
I have never used Hope - I love the Britishness and they look good but do they perform?
Love my Formula The Ones.
Avid codes. They aren't light like the formula brakes but they actually work and are easy to bleed. I had a set of new formula the ones on my dh bike and they were dreadful so sold them and went back to avid. A couple of mates have saints and both agree that my new codes are a lot better. Saints/ shimano may be great at stopping you dead occasionally but they are so inconsistant with their power. I had a set of the new xt trail brakes on my trail bike and they were again really inconsistant so i have gone back to a set of elixir cr's and can't fault them
Saints if you have the cash.
Hope V2's... they'll stop ya.
Mine (all three) have worked a treat with NO maintenance for 4 years.
Modulation, power, adjustability.
And, i'm not even a big hope fan either. They do work tho'.
Codes or Code R's
On a recent mtb magazine test the V2's were in the top 3 for power. They have loads of power if you ever need it and if you want more power you can get the vented rotors.
Shimano SLX brakes are acearama. I'd go Shimano every time.
SLX
Have seen a few sets of Saint clipers with XTR levers which are supposed to be amazing, failing that XT or Saint setups or Hope kit.
Shimano all the way, the rest of the them have no modulation at all
As for hope good for the 1st 2 rides then there a nightmare
Thats the reason the British dont make cars any more
Hope ............Austin Allegro ๐
Hope V2's plenty of modulation with the ability to detach your retinas if required ๐ฏ
New SLX are pretty impressive for the money.
Errr...Hope have way better modulation than Shitmano, everyone knows that.
Really? Mine seem to be fit and forget, like many others. My brothers Shitmano XT's however, haven't worked properly for more than one ride.
Budget dependant, but i'd probably stick a set of the new XT's on there. Good balance of power, weight & sensible price.
No budget, Formula. More powerful than Hope & a shed load lighter.
I assume you're happy with the Elixir 7s as you're moving them over.
Why not get a second set?
Will keep spares / service items simple.
Or get a second set and fit a Code calliper to the front?
I run 185/160mm (f/r) rotors with a Code calliper up front, Elixir calliper at the back and Juicy Ulitmate levers on my Shocker and have never had an issue with being under-braked (lots of Alps use). The brakes feel great, really well modulated. Not on/off like others. But that's how I like them set up.
To be fair I run the same set up on my Hustler (185/160) and Stiffee (160/140) too.
Should add, I'm not a whippet or easy on machinary.
How do current Shimano brakes compare for power? They all look like a very similar design, do they just vary in weight or do they get more powerful the more expensive they are?
I have some Deores on my BFe and am very impressed with them. Would some SLX be more powerful? Or just lighter and more adjustable?
2nd vote for Formula The Ones. Not cheap though ๐ฏ
Formula have a factory sale every year where I got mine less than half retail price, although I doubt you want to wait until October...
Saints are supposed to be very good as an alternative, and pretty good value.
Cheers, Rich
I don't have a bad word to say about my Hope V2s or my Hope X2s
