Trek remedies using 135mm axles have an extra long rear skewer (210mm apparently though I haven't measured mine to check). The lever is damn small and uncomfortable to use so I wondered if anyone knew of another version that could be used instead? I'd ideally love a shimano shape lever but not sure if this is possible or not.
210???
Salsa and Hope do skewers for 170mm fat bubs.
I have just googled and see there are products on ebay.com, $37 posted though!
Just get a normal length Shimano skewer, and use the nut/cam/lever from that with the threaded rod from your existing skewer?
So the current skewer might just unscrew from the lever mechanism? I've no tried it yet.
Found one at JE James, daft system!
I tried to unscrew the lever from the bar but even with the molgrips as tight as possible it wasn't budging.
