Where to get a 1mm ...
[Closed] Where to get a 1mm headset spacer?
 IA
Ok, due to playing a bit of mix-n-match with headset bits for various reasons, I need a 1mm 1 1/8th spacer to space out a bearing cover. I found a 2mm in my LBS, but ideally, it needs to be a 1mm.
The only ones I've found are the middleburn ones, but they come as part of the spacer pack, for £9. And I don't want to pay £9 for a 1mm spacer!
Any ideas anyone? Does anyone other than middleburn make such a thing? Or it doesn't have to be alu, I'm sure I've had various headsets with washers/rings/whatever that would do the job, can anyone point me at such a spare?
Posted : 18/02/2009 11:59 am
phone middleburn and ask for it seperately - they did that for me with some bolts once.
Posted : 18/02/2009 12:07 pm
binned one yesterday
Posted : 18/02/2009 12:10 pm
Would a 32mm plumbing washer/seal do the job? I guess the usefulness of the suggestion depends on you having plumbing bits sitting around.
Posted : 18/02/2009 12:11 pm
use a 2mm spacer. The topcap/stem can deal with it and once it's fitted you'll never know! 🙂
Posted : 18/02/2009 12:12 pm
 IA
The 2mm is what I have, and isn't ideal. It's to space out a bearing cap, not for the usual use. I need to create enough of a gap for it not to jam, but little enough I can fit an o-ring to seal it.
Hard to explain, but trust me it wants to be 1mm.
Don't have much plumbing kit about.
Posted : 18/02/2009 12:52 pm
aha: boodging. Understood.
Posted : 18/02/2009 1:28 pm
Where are you? In London? I've probbly got a 1mm one about somewhere.
Posted : 18/02/2009 1:40 pm
 IA
Yeah, it's a bodgetastic game of headset-lego, though actually works pretty well.
In edinburgh I'm afraid.
Posted : 18/02/2009 1:41 pm
Oh dear. Try a LBS? They often have odd spacers and bits lying around.
Posted : 18/02/2009 1:43 pm
