Where to buy Hollow...
[Closed] Where to buy HollowTech II Pinch Bolts?
[#755509]
Being a ham-fisted oaf, who's also really keen to stop his BB creaking, I've rounded off one of the bolt heads.
Where can I gat new ones? Not had much luck searching the net, or crc, wiggle and merlin.
Cheers for any help.
Posted : 03/08/2009 9:56 am
Try mailing Househusband, he pointed me in the right direction only a couple of weeks ago
Posted : 03/08/2009 9:59 am
A M6 x 16mm cap head set screw is what you need.
Posted : 03/08/2009 10:00 am
That's really impressive to round off a steel bolt but not thread the soft alu of the crank itself...
Posted : 03/08/2009 10:04 am
Cheap allen keys is what does it.
All mine are cheap
Posted : 03/08/2009 10:06 am
What dibbs said
Scienceofficer - Member
Threads are incredibly strong and it is difficult to strip them - even stripping an M5 with proper engagement in decent alu would take more torque than most of us could manage with a AK.
And the supplied bolts are crap, get std ones.
Posted : 03/08/2009 10:10 am
 cp
Bulk SS from Ebay. Had same problem a couple of years back as the standard bolts are made from cheese! Can post you a couple if you want - email in profile.
Posted : 03/08/2009 11:10 am
Thanks Alan,
I'd just found some on Tibolts.co.uk and I thought I'd get some bolts for my Thomson stem while I was at it, so you've saved me about £20!
Cheers,
Ed
Posted : 03/08/2009 11:17 am
Some bolts have heads which are too big to work as HT2 pinch bolts, there was a lot of talk about it on WW. I'd either go with a first hand recommendation, or just get the OEM ones.
Posted : 03/08/2009 11:25 am
The OEM ones aren't really long enough IMO. 20mm is more like it.
Posted : 03/08/2009 11:41 am
Charlie, where did you get them from? I'm in need of a couple.
Posted : 03/08/2009 12:20 pm
