Where to buy Crossm...
[Closed] Where to buy Crossmax SX 2011 20mm to 15mm Adaptor in the UK?
Thinking of picking up a set of the older 2009/10/11 Crossmax SX wheels, looks as if they only come with a 20mm option on the front. After some research looks as though you need to buy an axel conversion kit, have only seen in the US so far and looking for a cheaper option before pulling the trigger.
Posted : 06/07/2014 1:42 pm
Bump for the evening crowd.
Posted : 06/07/2014 8:56 pm
I have the same wheels and always assumed they're not convertible until recently saw them with 15 mm front.
Not sure if these will fit?
http://www.purebike.fr/en/vtt-f1/roues-f58/hubs-and-parts-f62/mavic-15-mm-adapters-a5100.html
Posted : 06/07/2014 10:02 pm
Thought my brand new set came with all the converters in a mass of packaging.....but I want to hang on to my adapters for the future in case of fork changes etc.
Posted : 06/07/2014 10:04 pm
The wheels in question are grey rims white hubs if I'm not mistaken? They're 2009-11 model years.
The 2012 ones (white rims and hubs) are fully convertible. The 2009-11 ones may be convertible as well but the 20 mil caps are definitely different externally - they just don't have the slot for removing the caps as shown in the online step-by-step conversion instructions.
Posted : 06/07/2014 10:28 pm
Ah right.
Posted : 06/07/2014 10:29 pm
Yes 2009-11, I saw this
http://www.risseracing.com/QR-15_SX_axle.shtml
I wondered if there was anywhere in the UK I could get, works out about £50 from US.
Posted : 06/07/2014 10:32 pm
Ah, Risse Racing it is then!
I think it's their custom axle and probably the only known (to me at least) way to convert it. So 2012+ conversion kit will definitely not work.
Posted : 06/07/2014 10:42 pm
I'm pretty sure the Risse Racing axle is your only (off the shelf) option...it's what made me buy a set of ST's instead back in 2010, as I already had a 15mm fork.
Edit - beaten to it by AndreyE
Posted : 06/07/2014 10:46 pm
Cheers, I've got a bike with 20mm & one with 15mm ideally I'd run them on both...was hoping there was a cheaper more local option.
Posted : 06/07/2014 10:51 pm
