where can i get the dial from? or even the whole damper unit?
pushloc is cluttering up my bars
the classifieds, tf tuned or just do pp's bodge which disconnects the spring from the inside of the damper
still need the dial tho
TF Tuned have them new. Email me for instructions on how to do it. 🙂
emailed you a bit back - check your inbox 🙂
How easy is it do do the reverse of this - i.e. add a pushlock/poplock to a set of revs that have the fork-top lever?
swap me for mine - win - win
If I knew how to do it I'd be very tempted!
kevin - remove the dial with the grub screw, undo the big hex nut on the top of the fork leg, twist and pull the damper out. put new one in - top up with oil - done.
5 Mins max.
Where are you based?
how much for you poploc, but which type is it first?
rob, i'm near falkirk. If your're nearby, maybe we can do a deal. If not, i'll probably give the fork-top lever a shot. They're brand new forks, not yet fitted.
peak district 🙁
£36 on tftuned for the fork crown lever for 09/10 ones. 😯
As yummy looking a fork as mine is, I might try disconnecting the return spring inside and then bodging something temporary onto the blue 'bobbin' to move it round by hand.
Email to everyone who emailed me so far..... I think! Sorry if I missed you but there's been quite a few recently! Please try again if I did.....
Julian - what about an O ring?
Thanks for the guide PP, very impressed.
How is that replacement knob different - except for the obvious 'sticky-out bit'.
Can't you just use the original (with an O ring to stiffen things up)?
my thought also
