I've been on google looking for cable sleeves, plastic sleeves to run over cables to protect the frame underneath. I've had them on bikes but cant find any for sale. and no i dont mean heli tape or the usual cable outers. These are a bit wider than the red plastic cable on a can of wd40... please somebody put me out of my misery.
nooooo, long stretches of plastic to run along the top tube .
eBay .... ?mm silicon sleeve.
cheers mooman but looks a bit thick / heavy for the job.
I think you're talking about fully sealed cables?
As far as I was aware the plastic is to prevent the ingress of water and dirt into the cable outer, used in frames that don't allow for full outers.
But I have only seen these as part of a full new cable kit, not on their own.
nah, not fully sealed cablesets. I guess I'm going mad and my memory is like a sive. ๐
Straw, it's generally called, from your local LBS.
Or if you want to be more sophisticated look for [url= http://www.fishingmegastore.com/mustad-silicone-rig-tubing~3823.html ]silicone rig tubing[/url] from a sea fishing shop, which you can get in a variety of colours and doesn't rattle like straw sometimes can.
I think I know what you mean but have only seen them in fully built bikes. In hi early, I have always removed them as they scratched my frame and rattled. This doesn't help I know, sorry.
i got transfil kits from wiggle a while back that have what you're looking for.
[url= http://www.wiggle.co.uk/transfil-kble-shimano-outer-brake-casing/ ]here[/url]
how about pump tubing from a pond-shop ?
Jagwire do some....
[url= https://www.google.co.uk/search?q=Jagwire+Tube+Tops&oq=Jagwire+Tube+Tops&aqs=chrome..69i57&sourceid=chrome&espv=210&es_sm=93&ie=UTF-8#es_sm=93&espv=210&q=Jagwire+Tube+Tops&tbm=shop ]Jagwire Tube Tops[/url]
rusty, looks just the job! perfect, although I'd never have thought it was a fishing thing.
cheers amigos.
This is what you need [url= http://www.wiggle.co.uk/transfil-gear-cable-waterproof-kit/ ]Protection[/url]
Try heat shrink, saw a kit of all different sizes and colours in a DIY shop recently
I remember the stuff, haven't seen it for years though.
I prefer donuts tbh.
If you use the fishing tube, make sure you get the size right. 1.5mm will just fit on gear cables, 2mm is easier and 3mm for brake cables (from memory)
I think that this is what I've bought from the LBS
[url= http://www.amazon.com/Jagwire-Black-Housing-Liner-Cables/dp/B0029LF1XO ]Jagwire Seal Liner[/url]
goodridge do blue stuff in their kit.
[url= http://www.chainreactioncycles.com/goodridge-gear-cable-kit/rp-prod22234 ]goodridge kit[/url]
