Where do you buy yo...
[Closed] Where do you buy your suspension fluid from?
Just from the scary Fox stanction thread I've been guilt tripped into getting some Suspension Fluid for my Fox Float 36s (Not Kashima.
So where's cheapest?
Is the official Fox the best?
I believe I need 7wt and Fox Fluid?
Thanks!
Posted : 02/09/2011 11:23 am
To do my Rebas and Vanillas I used Silkoline from the Yamaha dealer.
About half the price.
Posted : 02/09/2011 11:40 am
For damping duties, I use motorcycle suspension fluid (have a look on the PVD wedsite and there's a table that matches spec). For sloshing around duties, I use motorcycle engine oil as it seems to cling better and have a greater resistance to wear.
Posted : 02/09/2011 11:50 am
PJ1 usually or sometime Yamalube [I get that free though]
Or sometimes I just buy Fox as the bike shop is nearer than the motorsport shop I use
Posted : 02/09/2011 11:53 am
I ignore the arbitrary wt rating (which isn't a fixed standard, and not only changes between brands, but even between different ranges of the same brand!), instead using centistokes, and get the equivalent weight of Castrol Synthetic fork oil at either Halfords (500ml 10w £7.49) or off Amazon (500ml 5w £6.61).
The viscosity of most common suspension oils in centistokes can be found [url= http://www.pvdwiki.com/index.php?title=Suspension_Fluid ]here[/url]
You can mix viscosities to arrive at your chosen weight of oil, and Shell have a free program called Shell Bunker Calc which can do the calculations for you.
Posted : 02/09/2011 12:01 pm
Wow this is a lot more complicated then I imagined! 😀
Posted : 02/09/2011 12:37 pm
Castrol motorcycle fork stuff here.
So far so good .....
Posted : 02/09/2011 12:47 pm
 mboy
I use Putoline from a local MX shop cos its about £9 per litre and they stock everything from 2.5w right up to 20w
You MUST use fully synthetic whatever you go for though, but most of the top brands (Silkolene, Castrol, Putoline, CVI, Shell etc) all make oils up to the job.
Chain reaction sells fork oil too nowadays if you just want to be lazy and order off them...
Posted : 02/09/2011 1:08 pm
