Where can I buy all...
[Closed] Where can I buy alloy inserts for a fox rp23 shock?
[#3868092]
As title, have replaced middle bushes but still have some play in rear swingarm. Does anyone know where I can buy spare alloy spacer/inserts?
Posted : 13/04/2012 4:55 pm
TF Tuned would be my first port of call....
Posted : 13/04/2012 4:56 pm
bearing supplier should sort you out.
Posted : 13/04/2012 5:12 pm
Thanks, found heavy duty kits on tf tuned site
Posted : 13/04/2012 5:21 pm
If the problem is play in the swingarm, why are you replacing shock hardware?
Posted : 13/04/2012 5:40 pm
Worn DU bushes will give you play in the swingarm (that you've replaced). The mounting spacers won't effect play in the swingarm
Posted : 13/04/2012 5:43 pm
Loco Tuning sell the spacers, I got a couple from him the other day.
Posted : 13/04/2012 6:35 pm
