I'm newish to discs - how do I know when to change the pads?
When there's metal rubbing on your disc and all of the pad material has worn away. That's when I change them anyway. You could change them earlier to be on the safe side but you'll end up spending more money in pads.
I would try not to get metal on metal contact = you can score your discs. I change 'em when they are paper thin
I have hopes and the springs start to rub on the disc as the pad is on its last legs so thats a good warning
Im rather decadent and change mine when they're around 1/2mm as I hate running out of pad mid descent.
Does scoring the discs actually cause problems? I am skeptical.
A bit of scoring, no - really, the bigger problem is metal-on-metal doesn't provide as much friction.
A few pads have a wear groove in them - when the groove is gone, replace - but with most it's easiest to just eyeball from the top.
Well yes. I only ever change my pads when I can hear the metal-on-metal.
When it's metal on metal and there squeeling like a banshee.
When they look like they could do with it... Otherwise that metal-on-metal contact tends to end up happening at a really irritating time.
Remember, just because you've removed a set of pads doesn't mean they have to go in the bin, if they've got any meat on them then they still make useful spares... If you need to do a trailside replacement it's easier to fit a half-worn pad, and they won't need much bedding/mating in done either.
Does it go bad or not work well as before?If it doesn't work well enough,it is time for you to change a new one
