What's this stuff c...
What's this stuff coming out of my (bicycle wheel) rim?
Took the valve out of one of my road wheels to put another layer of tape on and a load of this powdery stuff came pouring out. I managed to get a lot out but I can still hear some sloshing around the rim cavity. What is it? Dried sealant? Shouldn't be there. Alloy corrosion? Dried tape residue? My best guess.
Gorilla tape, alloy rim, unknown nipple material (factory wheels).
20241011_092539
Posted : 11/10/2024 10:31 am
What does it taste like?
Posted : 11/10/2024 10:33 am
tomhoward, nuke, matt_outandabout and 3 people reacted
Crushed up rhubarb and custard sweets and childhood disappointment.
Posted : 11/10/2024 10:34 am
 Yak
Sherbert. Probably lemon.
(looks like alloy corrosion)
Posted : 11/10/2024 10:39 am
Alloy or carbon rim?  If it's hard and crumbly, it's possibly alloy corrosion, but that's a lot of material (especially if a carbon rim).  If it's soft and crumbly, I'd suggest it's some combination of the tape, water and sealant.  If it's a carbon rim and there's a decent cavity, it could be that it's part of the mandrel used to form the wheel and hasn't been properly removed and is no breaking down.
Posted : 11/10/2024 10:40 am
anono and anono reacted
Alloy rim.
It's quite dry and crumbly, but rubbing it between my fingers leaves them feeling slightly sticky, which makes me think not corrosion. Think it probably is the dried adhesive from the back of the tape over the spoke holes. Never noticed this before though and I've always taped rims with Gorilla tape <shrug>
Posted : 11/10/2024 10:46 am
claudie and claudie reacted
Posted : 11/10/2024 10:49 am
 igm
I’ve had mud and sand get into the rim void. It’s only the really fine stuff that gets in and dries to a powder.
Posted : 11/10/2024 10:50 am
I have had similar when on wheels that have been taped with gorilla tape, but never on rims that haven't. Gorilla tape is porous isn't it? See https://www.singletracks.com/mtb-gear/why-gorilla-tape-isnt-ideal-and-other-mtb-tubeless-taping-tips-with-drew-esherick-from-stans-notubes/#:~:text=He%20mentioned%20that%20sealant%20slowly,proper%20tubeless%20tape%20is n't.
Posted : 11/10/2024 10:54 am
b33k34, Daffy, b33k34 and 1 people reacted
Nice.
Posted : 11/10/2024 11:29 am
Is tubeless tape really so expensive that people are willing to use cheap alternatives? I'm a right skintflint, but I have a drawer full of different widths of proper tubeless tape.
I should've stayed with Mavic wheels, then I wouldn't have needed it.
Posted : 11/10/2024 11:56 am
robola, thepurist, thepurist and 1 people reacted
@nixie
"He mentioned that sealant slowly evaporates through the thick black tape just like it does through the weeping sidewalls of tires because Gorilla tape is porous — where a proper tubeless tape isn’t. That evaporated sealant then enters the inside of your rim, which isn’t anodized and speeds the corrosion of the rim and aluminum nipples."
Posted : 11/10/2024 1:10 pm
My back wheel developed a quite loud, distinct rattle coming from the rim. Now it's stopped.
Posted : 11/10/2024 1:45 pm
I had a surprising amount of mould inside alu handlebars which was probably caused by a tiny amount of postit note glue and water. Didn't look like yours though, was fluffy.
Maybe combination of sealant, tape glue, and tiny mud/sand grains that came in via muddy water?
Posted : 11/10/2024 10:34 pm
Have you tried snorting it?
Did all your mates think you were a dickhead despite you have a great time?
Were the wheels it came out of off a Delorian?
Can you post it to me?
Posted : 11/10/2024 10:52 pm
Tom83 and Tom83 reacted
Yea I think gorrila tape leaks after a while, and probably causes problems like this
Annoying, as it is by far the easiest tape to install ime
Posted : 11/10/2024 11:07 pm
You've discovered a portal to Breadcrumbia
Posted : 12/10/2024 12:10 am
Fairy dust? Sprinkle it on something to see what happens. Or maybe angel dust?
Posted : 12/10/2024 8:24 am
