What's the stu...
[Closed] What's the stuff you dribble on to nipples
...after you have tensioned a wheel to lock the spoke nipple?
Thanks
Rich
Posted : 28/12/2012 8:18 pm
Childish s**** from the thread title
Posted : 28/12/2012 8:19 pm
Nothing?
Seriously, if the spokes are tight enough you won't need anything, and if the wheel does need retensioning you'd be stuffed. You can get nylock nipples from DT if you really want...
Posted : 28/12/2012 8:20 pm
Soak nipples in linseed oil before building
Lubes them during build and sets semi solid to act lke threadlock
Me - i soak em in light oil.
Posted : 28/12/2012 8:28 pm
Thanks chaps.
Posted : 29/12/2012 12:18 pm
I use peanut butter and maybe a little vendetta
Posted : 29/12/2012 12:23 pm
DT sell loctite for this purpose, I agree with Ben tho.
I imagine you're thinking of Spoke Freeze? I've used it, the while point is that it's not a particularly strong thread lock.
Posted : 29/12/2012 12:24 pm
I'm guessing honey is acceptable.
Posted : 29/12/2012 3:13 pm
Candle wax...
Works on both kinds!
Posted : 29/12/2012 4:05 pm
Manfat
Posted : 29/12/2012 4:08 pm
If you are hammering downhill and are a total FB then you could loosen your nipple nuts.
In that case loctite blue can help.
I bought a pair of superstar AM wheels and couldn't keep them tight so used loctite and not had a problem since.
Chris
Chocolate! ๐Ÿ˜€
Posted : 29/12/2012 5:28 pm
Just use Dt prolock as above
Posted : 29/12/2012 6:42 pm
