What's the sti...
[Closed] What's the stiffest spring for a 2" DHX?
[#1366163]
As above really. Is there anything stiffer for a 2" stroke shock? I know they do stiffer springs but as far as I can see, only for 1.5" shocks.
Posted : 27/02/2010 12:23 pm
800lb x 2.35
Posted : 27/02/2010 12:25 pm
As I thought, thanks for confirming.
Looks like I just need to try harder in fat club then!
Posted : 27/02/2010 12:28 pm
 GW
What does it matter what the stiffest is?
surely you only need to look for the spring weight you actually need 😕
Posted : 27/02/2010 12:30 pm
 GW
what bike is it for?
I'd look at getting something with a lower leverage ratio if you need more than an 800lb spring.
Posted : 27/02/2010 12:31 pm
I'm looking for the stiffest to see if there is something bigger than I already have. As can be seen from the first three posts, I'm already at the top of what I understand to be available. It's a turner 6 pack (HT) and I've just tried a 800 lbs spring with is about right but I didn't haver all my kit on. Just wondered if there might be an 850 or the like out there that I didn't know about. However, I think will anything over 800 the issue is the free length. I'm not sure it's possible to make a spring of that weight with a 2" compression and a free length under 130mm.
As for changing the bike, no thanks, I'm quite happy with the 6 pack once I et this sorted. And yes, I've already had it pushed for my weight. (220-210 depending on kit and how much water)
Posted : 27/02/2010 12:48 pm
 GW
You could have a spring made, it's not massively difficult or hugely expensive, just find a spring maker (try in the yellow pages).
Posted : 27/02/2010 1:17 pm
 LoCo
Yep true about the free length onza, it's also whether the spring could have enough travel due to the number of coils needed. It's like over preloading a spring it would become coil bound/bottom out before full travel of the shock was achieved, this destroys shocks pretty quick.
Posted : 27/02/2010 3:27 pm
