What's the sma...
[Closed] What's the smallest sprocket size that will fit on an Alfine?
I know that the Alfine sprockets only go down to 18 tooth, but as it's a standard hub gear fitting you can use Sturmey Archer sprockets, which are available down to 12 tooth.
However, I am pretty sure that if you put a 12 tooth sprocket on an Alfine the chain would foul the hub and maybe also the shift mechanism.
So, what's the smallest sprocket size that can be used successfully?
Posted : 15/03/2011 11:35 am
I have a nexus 16 on mine
Posted : 15/03/2011 11:52 am
Thanks for the reply. I had a 15 tooth in mind - do you think it would fit ok?
Posted : 15/03/2011 11:53 am
