whats the eye to ey...
[Closed] whats the eye to eye and stroke measurements of a 2009 spesh enduro fsr
as above, i need to replace my afr rear shock and ive killed 2 now so looking a fox rear shocks. not 100% sure what the sizes are though.
thank you
Posted : 13/06/2012 7:27 pm
200 x 57mm, I have a RP2 HV you can have for 80 posted if you like? It was on my enduro until I went coil.
Posted : 13/06/2012 8:15 pm
i was thinking about going coil as i have fox 36 on front now. is the shock in good working order??
Posted : 13/06/2012 8:28 pm
Pease the shock is in excellent working order, I have fully maintained since ownership. It has not been used since sept last year, I stripped cleaned and put new seals in it after I took it off the bike. It also has brand new bushes installed.
Posted : 13/06/2012 8:49 pm
im interested fella.. mines making some bad noises and im off to the alps in 3 weeks.
Posted : 13/06/2012 9:23 pm
I'm in France at the moment (not alps though) I'll be back on Saturday and will get some pics sorted if you like.
Posted : 13/06/2012 9:30 pm
that would be great. thank you fella.
Posted : 13/06/2012 9:44 pm
"i need to replace my afr rear shock and ive killed 2 now "
Killed it twice how?
Specialized 5year warranty not upto much?
Or aren't you the original owner?
"mines making some bad noises"
squelchy noises as it goes up and down? IM(limited)E that might be solvable with an air can 'service' (ie unscrew air can, clean, grease, reassemble)
Posted : 13/06/2012 11:23 pm
one seized, been told it needs a full service the second i bought second hand. Im not the original owner of the frame but do have the original invoice of sale. when i asked the shop they said it didnt matter because even with the warranty they wouldnt replace it as i would need proof of servicing which i dont have!!
thanks for the advice tho. i may unscrew it and clean/regrease to see if that helps!! not sure why but i dont touch the rear shocks. ill service every other part of my bike.
Posted : 13/06/2012 11:34 pm
