What's the biggest ...
[Closed] What's the biggest size tyre I can fit on Mavic XM719's? (Kenda sizing helpful)
The question is in the title... I am currently running Kenda Nevegal 2.1" but was wondering what would be safe to use. IIRC Mavic say 2.3" is the upper limit, but given that tyre widths are so subjective I was wondering what people find acceptable? Would Kenda 2.35" be OK, or as they come up large will I die in a bloody mess?
Posted : 17/06/2009 11:35 am
It'll be fine & dandy
Posted : 17/06/2009 11:36 am
Hurrah! If I die in a bloody mess it's your fault though.
Posted : 17/06/2009 11:44 am
it'll be fine. i'd say 2.5 was the limit.
 RJM
i'm running a 2.5 on mine and i would say that was going a little too big as it starts to fold in the corners
Posted : 17/06/2009 12:00 pm
RJM - what make of tyre?
Posted : 17/06/2009 12:09 pm
I've found them a little too narrow for 2.3 tires upwards and they try and roll off the rim!
Posted : 17/06/2009 12:12 pm
 RJM
they are maxxis.
2.35 kenda will be fine.
Cool.
Posted : 17/06/2009 12:14 pm
Running 2.35 Nevegals on XC717's here with no problems.
No lightweight either at 16st (and falling slowly). ๐Ÿ˜ฎ
Posted : 17/06/2009 12:16 pm
I run Kenda 2.35's on my 719's without a problem. Even the lightweight Kevlar ones feel rock solid with no hint of rolling off on anything.
It's worth bearing in mind that a Kenda 2.35 Blue Groove or Nevegal sizes up the same as a Maxxis Minnion 2.5.
Posted : 17/06/2009 12:17 pm
It's sort of dependent on the tyre sidewall and how much pressure you ride with too.
Tyres with more flexible sidewalls or lower pressure will fold/roll more easily. eg. a 2.5 downhill tyre with 35psi might be ok, but a 2.3 trail tyre with 25psi might not....
Posted : 17/06/2009 12:24 pm
I've used 2.35 Kenda Nevagals DTC on XM719 rims no problem
Posted : 17/06/2009 12:27 pm
Ditto here.
Posted : 17/06/2009 12:34 pm
takisawa2 - Member
So a 2.35 High Roller would fit perhaps?
Posted : 17/06/2009 3:10 pm
I used a 2.35 on a 717 and it rolled horribly.
I put 719 rims on and I'm running 2.4 contis happily now.
Posted : 17/06/2009 3:18 pm
