What wifi router an...
[Closed] What wifi router and access point?
What's good? Separate access point that works seamlessly with the router. Router should be IPv6 compatible and also support WAN connection (just in case I ever get some sort of FTTC type provider).
edit: sorry wrong forum.
Posted : 22/10/2011 8:56 am
I use an Apple Time Capsule as my router and a Netgear ADSL MODEM. I have Macs so there is clearly and advantage to having all the other facilities built in (and there are a surprising amount).
What broadband supplier do you use? Rememeber that regardless of the router you use, BT-supplied connections do not support IPv6 and have no plans to do so.
Rachel
Posted : 22/10/2011 9:13 am
I use O2 regular ADSL+ at the moment.
No use for apple features at the moment. I'll probably be building / buying a NAS shortly as well for all my storage requirements.
Seems daft not to buy something that supports IPv4 & 6.
WAN port also seems like a good feature to have in case I change to a provider that requires a separate modem (BT infinity for example).
Posted : 22/10/2011 9:18 am
