What width rims for...
[Closed] What width rims for 2.6 up to 3.0? (27.5)
12 Users
Needs to be tubeless
Posted : 23/01/2018 11:23 am
35-40mm imo
Posted : 23/01/2018 11:25 am
Posted : 23/01/2018 11:32 am
Worth looking for an ETRTO chart that shows which rim widths are recommended for different tyre widths. There's one on [url= http://engineerstalk.mavic.com/en/the-right-tyre-width-on-the-right-rim-width/ ]this page[/url] amongst other stuff.
Posted : 23/01/2018 11:35 am
Will you be riding one width more than the other?
If 2.6in most of the time, maybe steer towards a 35mm internal rim - as you'll have more choice and save a bit of weight.
Posted : 23/01/2018 11:39 am
What max tyre width on an i29 rim ..Im thinking of upping it to a 2.5 on the front ..
Posted : 23/01/2018 11:59 am
Read the supplied link?
Posted : 23/01/2018 12:00 pm
Can't be arsed to be honest ..a quick nod in the right direction would have sufficed ..if you like an honest answer...instead of an arsey reply ..
No matter though I will be doing it anyway ..
Posted : 23/01/2018 12:22 pm
I've been considering the Hope 35w wheelset for this purpose. However it might just be a jack of all, master of none, i.e. not optimal for either purpose.
If you were just running "Wide Trail" tyres you could drop to 30mm internal and save a bit of weight. Also you can drop skinnier if you need.
If you were just running 2.8 to 3.0 tyres then you'd be better with 40mm internal (I think).
Posted : 23/01/2018 1:00 pm
A mate was running various tyres from a 2.3 MM to a 2.8 Maxis something on a 35mm Ibis, always seemed happy with it 🙂
Posted : 23/01/2018 1:11 pm
Using 35mm rims with 3.0 Nobby Nics, seems to work fine.
Posted : 23/01/2018 1:13 pm
Which would be fine, if you'd read it yourself and noticed it doesn't cover 2.6"-3.0" tyres wouldn't it?
Rule of thumb with big fat tyres is 2:1 as a minimum (i.e. a 50mm rim is ok with a 4" tyre). So the minimum you should be looking at is 37-38mm, although a 35 would probably be fine in reality as a lot of plus tyres are optimistically sized (a surly 2.8 is only 2.8 on a 50mm rim, the actual casing is about the same size as a lot of 2.5" tyres)
Posted : 23/01/2018 2:04 pm
 gil_
Using these with 3.0 both 29 and 27.5, as good as Velocity but way cheaper and tubeless with a bit of Gorilla tape...
[url= https://www.superstarcomponents.com/en/alex-supra-35-rim.htm ]Super Cheap with "2018" discount code[/url]
Posted : 23/01/2018 2:36 pm
@gil_ :
this is really a bargain.
Have an trail-bike with Alexrims (I use tubes so) - nothing wrong with those.
Posted : 23/01/2018 3:28 pm
 gil_
Really impressed with them, been trying to find some Blunts/P35 for an age and these are just as nice, maybe a fraction heavier but a nice welded joint and £35 each
Peel the stickers off if you're a brand whore 😉
Posted : 23/01/2018 3:59 pm
Peel the stickers
haha. My bike with Alexrims: no of course not. The Alexrim stickers are o.k.!
£35 each
that's too good!
Posted : 23/01/2018 4:27 pm
I'm running 30mm internal rear for a 2.8 tyre, and 35mm internal front for a 3.0 tyre. Both feel great for me... they're the same tyres, and there is a noticable difference in tyre profile between the rims.
Very happy with mine, and the weights of the rims keep the combo feeling gooood without spending silly money/sacrificing durability.
YMMV
EDIT: pinkbike article on the whole sha-bang is a good read (cant find link, sorry)
Posted : 23/01/2018 5:14 pm
