What tools to remov...
[Closed] What tools to remove chain ring nuts and bolts?
Hi all, what tools do I need to remove the chain rings from a XT M770 set of cranks?
i.e. what size torx bit(if it is a torx bit!)to remove the chain ring bolts and what is the tool called that holds the nut at the rear of the rings?
Any links to where I can get hold of these would be great, thanks.
Posted : 25/04/2009 9:58 am
Couple of allen keys should suffice
(edit: sorry, XT may require torq bits)
Posted : 25/04/2009 10:04 am
Tools - helfrauds pro range are a decent price and quality.
Posted : 25/04/2009 10:40 am
A set of Torx keys/sockets and you might need one of these [url= http://www.chainreactioncycles.com/Models.aspx?ModelID=14305 ]Clicky[/url] for the back.
Posted : 25/04/2009 10:54 am
 TimS
Used to be that you'd need a Shimano TL-FC20 for the back side of the bolts. I think that a fat screwdriver would do the job though.
Posted : 25/04/2009 12:10 pm
Trusty...just what I was looking for, cheers.
Posted : 25/04/2009 1:50 pm
