What tools for repl...
[Closed] What tools for replacing Hope Pro II bearings?
Front wheel is starting to feel a bit rough after a few years use - reckon the bearings need replacing. What tools do I need to do this?
Posted : 03/10/2010 1:26 pm
 Ewan
Small pointy screwdriver to get the circlip off (or circlip pliers if you're felling posh. Something to **** the bearings out with (24mm socket?), something to put the new bearings in again (again use a socket).
The front one is very easy.
Posted : 03/10/2010 1:44 pm
Hammer, WD40 and duck tape usually covers it
Posted : 03/10/2010 3:33 pm
where are you? i have the drifts your welcome to borrow (peak district)
Posted : 03/10/2010 3:45 pm
heat the hub and freeze the new bearings - it makes it much easier. Tie a cloth around the hub and pour boiling water over it.
I put my new bearings in by hand having done this ( well one needed a few taps) one just pushed in.
Teh correct drifts make it easier but are not essential
Posted : 03/10/2010 3:49 pm
TJ - not trolling. But does the freezing have an adverse effect on the grease?
Posted : 03/10/2010 4:16 pm
Can't see why it would.
Posted : 03/10/2010 4:20 pm
that means nothing lol
Posted : 03/10/2010 4:23 pm
 br
Just buy the Hope bearing tools - they work and make the job easy.
Posted : 03/10/2010 4:37 pm
did mine with a socket in 10 mintues (ok, I took my time), I say "mleh!" to your special tools!
Posted : 03/10/2010 4:46 pm
Temporary thickening would be the worst.
Posted : 03/10/2010 6:21 pm
DRifts were cheap enough to make it worth while. Them and a block of wood with a big hole drilled in it. And hammer for the obligatory ****ting.
Posted : 03/10/2010 6:24 pm
Call me naive, but how do you get the first one out with a socket? I removed mine for the first time the other day and had to prise one side out with a large screwdriver - only then could I knock the other one out from the inside (which obviously you can't do until one bearing is removed ๐Ÿ˜• )
Posted : 03/10/2010 6:38 pm
Band it out by hitting the axles(carefully) the spacer drives the bearing out.
Posted : 03/10/2010 6:44 pm
Ah, no axels - 20mm set up.
Posted : 03/10/2010 7:16 pm
long drift thru the center of one bearing knock the spacer to one side then drift out at an angle
Posted : 03/10/2010 7:20 pm
