Just taken a 2 brand new set of forks to a LBS and asked them to cut both steerers to 220mm as thats the sizes on the forks they're replacing.
Just got home and went to fit them ....they're cut to 200mm, both of em.
What do I do? How can I prove what i said to them? I know it was 220mm I said as I also said cut them down by 40mm.
Am I buggered?
Are the Bombers?
if so own em with them.
Two brand new sets of DTs!
We accidentally did it once, customer got some nicer carbon forks and an apology.
You're ****ed then.
DT's are no good for owning.
I'm absolutely gutted. 🙁
you can't - I presume they are saying you said 200mm?
They were close by the time I returned home. I only just went to fit them.
I took some forks into my LBS last week and they asked me to mark them with a felt tip pen where I wanted them cut.
TBH I was a bit put out by their request but not half as much as they were when I marked them as requested and also wrote 220mm next to the mark.
Sorry but i've got to ask why you get a LBS to do something as simple as cutting a steerer down?
No dissrespect to any LBs but I don't trust anyone to work on any of my bikes.
Take them back and insist they sort it. You are the customer.
not even me Stu?
thats awful! and also the reason i cut my own steerers
I do all of my own maintenance, but I dont have any facilty for cutting down forks.
No bench, no saw, no vice etc....
That is gutting, you'll have to see if they have the chopped off bits in the metal bin, so you can see how much was cut off and the original length of the steerer and take if from there.
How about not having the right tools Stu?
I'd speak to them face to face and as soon as. Not sure which way this could go.... How much business have you given them in the past?
sc-xc.
I'd let you mess with my "steerer" when ever you want mate. 😉
Buy a smaller frame with a shorter head tube..
£500 - £1200 if you include a private sale from the manager.
gizzard.
Buy them then.
Cheaper than two new forks..... 🙄
I can't belive they didn't quadruple check with you the length you wanted. Especially as they were cutting two pairs!
I would have measured them before leaving the shop too (assuming I would have let a LBS undertake this risky job).
Good luck getting it sorted.
Evans in Notts cut my new Floats 10mm too short recently and were grovelling big time once they realised. Offered new riser bars, new stem etc but they'd already done me a massive favour on the forks so left it.
Good luck Daffy i feel for you.
So your about £1200 out of pocket?
How about going back & asking the bloke to repeat what you asked whilst candidly recording it, if he says 200mm, then your proper ****ed 🙁
On the plus side if he says 220mm your LBS owes you for 2 new sets of forks, sorted.
I can't think of a better way of going about it, if you start by saying they got it wrong they will be very defensive...
Not sure i understand Stu?
how big is the business?
is it a chain or a small business?
How much business do you give them?
Did you not get a receipt slip when you left them, with an outline of the work to be done?
tbh if they are a largish shop I would imagine they should replace both forks if you are inistant and your headtube stem combo doesnt allow for adjustment.
They could easily write this expense off as an error by one of the staff for which they would be covered by insurance....
it would have been better if you had noticed immediately tho!
gizzardman - MemberNot sure i understand Stu?
There's no hope for you then is there.
Keep going to Evans and getting 10mm cut off your length. 😉
It was 16:45 when I left the shop by the time i got home it was nearly 17:30 which is when they close.
I only went to fit them at 21:00.
I'dve said it's a fairly big business, though not a chain.
Are the steerer tubes not replaceable?
If so get the shop to replace them at their cost.
I'm more likely to **** it up than shop TBH!
It ian't rocket science.
Cheers for the support Stu!
go in smartly dressed.
dont get angry
take both forks and all proof of the work, receipts etc, have all the details of the work, ie who did it and when, times, who you spk to, clear in your mind.
spk only to the manager/owner, have the DT contact details for returns/ ie steerer replacement with you and give it to the manager.
TELL him you want both steerers replaced within a month and give them deadlines, blag you have a holiday coming up.
be prepared for a sharp intake of breath, and manouvering, but you would be amazed what a confident manner can accomplish
I thionk it's time he went be byes
Stu, your'e about as much use as 'useless Jack McUseless' from Uselesseville, Illinois. The jobs done. In 19 yrs of biking I've never ever ever (recurring)taken my bike to a bike shop for anything cos I'm able to do it all myself. Unfortunately some people aren't as lucky as us.
As it happens Daffy I'm looking for some DT's with a short steerer. What travel are they?
Sorry Daffy.
Hope you get it sorted but you realy should learn from this.
gizzman.
I thionk you're even worsere at spelling than me.... 😯
Or are you "over tired"? 😛
esselgruntfuttock - MemberStu, your'e about as much use as 'useless Jack McUseless' from Uselesseville, Illinois
Na.
I ain't even that usefull. 🙁
I've got two:
EXC 150 QR - 150mm
EMC 100 QR - 100mm
Both are RLTC. Both are rand new with the tags still attached.
Is the middle of the crown (where the crown and steerer overlap) 20mm?
Did you say 220mm from the very bottom of the steerer (i.e. the bottom of the crown) or 220mm of exposed steerer?
Christ nearly[i] a hint of symapthy.
Hey CaptJon.
That got me thinking - but, no - tis a 30mm deep crown.
I cut down my steerer only with a hacksaw and an old stem, no other tools. It came out better than from manufacturers (rockshox).
If the shop didn't write down exactly what you requested they don't really have a leg to stand on. Did you get the Saturday staff? Keep calm and be assertive and it should be sorted to your satisfaction. Hope it's not ruined tomorrows ride.
Ask them to get the steerers replaced by DT.
If that doesn't work, put everything in a writing and ask for a formal response. Once you've got this you can open a small claims court. It'll be your word against theres, but if you can prove that its very unlikely you'd say 200mm (e.g. take the details of your frame, showing 200mm would mean the forks wouldn't fit) then you should win.
Tell them this is what you'll do if you can't get anywhere by being nice, and they should sort it before it gets this far hopefully!
Oh dear ... very tricky this ... as per CaptJon "
Or even from the top of new steerer?
I just used this cheapo £4 pipe cutter for the job and it cut perfectly.
I don't think putting a new steerer on is cost efficient. Surely they could just swap them on to some shop bikes or something.
Worst case they could ebay them 200mm isn't that bad and they'd probably get back cost?
Just go back, be polite, explain what's happened, and stick to your guns. do not back down. threaten them with legal action, if necessary. But remain calm, at all times.
And if they won't sort it, threaten them with me...
If you're not too far off route, the IWH cash refund/shoe weeing posse could call in and sort it for you on their return. 😆
Yeah, wot RudeBoy said
This is pretty terrible actually, please let us knowhow you get along with sorting thisout. I must admit I'd like to be a fly on the wall when you go in there....... I can see the colour draining out of the manager's face from here.....
are stiff open today...?
I use a pipe cutter as well. £5 and no other tools needed.
Surely they must complete a job sheet, so they have a record of what is to be done. If one person deals with the customer and another actually does the work how do they pass this info on correctly, ask to see the job sheet.
TELL him you want both steerers replaced within a month and give them deadlines, [b]blag you have a holiday coming up[/b].
The oldest irate/impatient bike shop customer excuse going! Usually not believed either...
That is absolutely staggering. I feel for you. Personally I don't much like cutting steerers myself, I always get paranoid I'm going to screw it up or end up with a ragged cut and an hours filing to do. So I'll happily get a shop to do it if I've planned my build properly.
Hope you get it sorted.
it's awful that your forks might e wasted, even worse that you've nothing to prove what you asked for, are you sure you haven't got what you asked for?
if you know what you requested and this isn't it then ask for them to replace the steerers/stanchion crown assembly. The DT's are press fit.
Surely no one would consider measuring the steerer from the bottom of the crown?
Did they have them in stock? Surely at worst they'll have to sell them at trade price, like Merlin did a few weeks back with some 185 mm steerer forks they ordered
I cut a steerer down too short myself once, only 10mm but it meant I had to go round Leisure Lakes in Preston measuring all the different stems on the bikes till I found one that had a short enough clamp. That got me 5mm a new headset got me another 5 mm and it all just fitted.
The last set of forks I fitted I deliberately cut steerer 10mm too long I dont mind having a 10mm spacer on top of the stem also makes the forks easier to sell on.
Exactly what "myheadsashed" said. Any shop worth it's salt will write out a jobcard or book the job in on the computer system. Did you see the member of staff do this? Of course, there's always the possibility that it was written down or entered incorrectly, which would explain BOTH being cut to 200mm. Hard to make a mistake twice.
You should also consider the possibility that you said "200" by mistake. Everyone makes mistakes!
For what it's worth, the one time i made a similar error, i replaced the steerer tube at my own expense. My cock up - my ass!
Daffy, STIF??????????????
Unfortunate word choices there! 😛
Poor daffy, what a nightmare. Mental note - in future write down your request and zip-tie it to the items in question.
Or, as has been said a few times, buy a hacksaw and a small file and save yourself the cash and effort. You dont even need a vice unless you have a weakling left arm and no ability to follow a line 😀
Sorry to hijack, but what pipe cutters are folk recommending for steel steerers then? Plumber mate reckons his copper pipe cutter won't look at steel steerers...
I've used the cheapest cutters Wickes sell without a problem. I've cut about half a dozen pairs of forks with them, you just need a wee bit of patience.
Pipe cutters do flare the steerer ever so slightly - never been an issue for me but something to be aware of.
"[i]what pipe cutters are folk recommending for steel steerers then?[/i]"
a hacksaw and a cutting-guide
Depending on my relationship with that LBS, I'd either be speaking reasonably to them or making it clear I was going to start a Small Claims Actions. Supply of Goods and Services, Sale of Goods, Duty of Care etc etc.
The fact that several rocket scientists contributing to this thread have pointed out that it is actually easy to do it yourself (in true, friendly STW fashion) is no defence for the shop, who should know better than to either fek it up or not double check with you if they had doubts. Long live the culture of litigation I say, if a reasonable conversation / comprimise doesnt get you anywhere.
Good luck
Stu (Lawyers4U)
ps - I would have used a permanent marker too!
Ton - not going to say until I've spoken to the bike shop in question tomorrow.
I definitely said 220mm as I also reitterated stating to take 40mm off the top. I also phoned in advance and asked them if they could do it on the day and the chap asked me if I knew how much I wanted off, I replied 40-50mm off both pairs.
There was no job sheet or anything....the chap took them off me and told me to have a look around while I waited....
chewkw-copied you with a Wickes pipe cleaner.
Took a few mins and then filed down straight and smooth-bingo.
Feel gutted for Daffy. Hopefully the shop will help.
If not how much on classifieds?
I'm fairly sure none of the rocket scientists were suggesting it was a defence for the shop. Some even offered methods of how to do it next time, in a friendly manner. However none can help with the problem of what to do next as the only thing you CAN realistically do is complain to the shop, which is common sense?
Thanks for all the advice guys. I went in with a calm demeanor and ..... well, they'd already heard about it via this thread.
Anyway, long story short (no pun intended) the bike shop has graciously agreed to replace the forks and absorb mine into stock.
If they're reading this, You have my thanks and loyal custom forever....though I will explain myself in more explicit terms next time I'm getting work done. 🙂
Glad it all turned out for the best - and another lesson (were it needed) on the virtues of remaining calm, on and offline. Hereendeththelesson.
Glad to hear you got it sorted in the end.
You know what to do next time though. 😉
RESULT! Pleased you got it sorted with the minimum of fuss.
Now which shop so i can bag myself a bargain pair of forks? 😀
Good to hear that and Daffy, FWIW, I'd post the shops name (unless they asked you not to) - for me, this would make me more willing to shop there, not less - everyone makes mistakes, it's how they're dealt with that's important.
Ah the advantages of posting a thread on STW. Glad you got it sorted.
However somebody didn't get as lucky when they posted a thread about specialized warranty, rung up the next day to blag they were the original owners and the guy said he'd already read the post on the forum and wasn't going to replace it!
Does ever bike shop/manufacture have people scanning these sites?
If they've got any sense, they do 🙂
what does 'absorb into stock' mean?
take the hit (eg absorb) in extra stock for now until they can sell them (200mm steerer will be long enough for plenty of people)
They're going to use them in a stew. 🙂
Hate to be unsympathetic - I really do sympathise, and not that you deserve to be taught a lesson, but hopefully the one lesson it will teach you is to do jobs yourself wherever possible.
I know cutting a steerer down isn't the MOST simple of jobs, but it is doable. My LBS has got a 4 week waiting list for repairs, and what angers me is that most of that will be people who simply can't be bothered to learn how to set up their gears correctly.
The only time i've let a bike shop cut the steerer of some forks down was when one of the sales guys offered to do them there and then when I was buying them, and it was before I'd paid for them...
