What springs also f...
[Closed] What springs also fit a Fox Van R 2010 rear shock?
do any other manufactures (i.e. cheaper) fit a fox van shock?
Posted : 25/05/2011 12:58 pm
Manitou. 2010 Van is the same size as Fox DHX and Manitou fit them.
Posted : 25/05/2011 1:07 pm
sure?
Posted : 25/05/2011 2:16 pm
Yeah they fit. I have one on a Van R.
Posted : 25/05/2011 4:19 pm
5th element as far as I know, since they licensed the technology for the manitou swinger range the shocks are almost identical.
That said call TF and ask them?
Posted : 25/05/2011 6:55 pm
What size are you after, I have a Fox 600x 2.35 if that's any good came of my 2010 Vanilla R , I'm using a Ti spring at the moment,
Posted : 25/05/2011 7:34 pm
many here
Posted : 25/05/2011 7:37 pm
I got a ti one of locotuning can't remember the name but much cheaper than a fox one.
Posted : 25/05/2011 7:51 pm
mike??
Posted : 25/05/2011 9:37 pm
I have Fox & Manitou springs here what size do you want? Posted Cheap - Run it through the TF converter and it will tell you
Posted : 25/05/2011 9:41 pm
450 x 2.5 or 2.8
Posted : 25/05/2011 9:42 pm
Closest I have is 400.2.75
Posted : 26/05/2011 7:22 am
The manitou is a slightly larger OD though . Not an issue unless your shock is shoehorned in. On my meta it was the difference between kissing the downtube and not!
Posted : 26/05/2011 7:40 am
My Manitou one is slowly eating away at my Van R with a light scoring action from the ID under compression. I though it was due to over preloading but its not and Loco said it does sometimes happen.
Posted : 26/05/2011 8:58 am
isn't the manitou a larger inside diameter
Posted : 26/05/2011 10:22 am
