What size rings for...
[Closed] What size rings for double & bash?
17 Users
I'm about to go back to a double & bash from 1x9. Feeling the need for bigger & smaller gears than I get with 32T and an mtb cassette. I've previously ran double & bash with 32/22T and road/mtb cassettes.
What size rings are people running? I'm thinking 36/26T or would that just be wrong, running a short cage xt mech on rear too.
Posted : 07/01/2011 6:02 pm
36/26 is what i run its perfect for trail riding great for around the woods etc and the 26 is fine for going up the steep stuff.
didn't have a problem with any of the hills in Wales.
Posted : 07/01/2011 6:06 pm
22/36 here. 🙂
Posted : 07/01/2011 6:08 pm
think I have 36/26 too - doubt it's crtical so don't buy new 'til yoyu've tried what you have already
Posted : 07/01/2011 6:10 pm
22/36 on both of mine, with an 11-34T cassette, though I'm tempted to try 24/36 I do like to have the crawler gear- even if it's only so I can say "Well I'm not in the lowest gear"
Posted : 07/01/2011 6:26 pm
I know a lot of people go for the 36t option but I tried it and just didn't get on with it. I was finding I had to drop down to the 22t ring early as the 36/32 was too high. As a result I ended up shifting between the big and small ring a lot. I bent 2 36t rings.
Went back to 32t and I stay in that a lot, much happier now
I live in W Yorks and tend to ride where there's a lot of steep ups and downs. 36t may make more sense for me in flatter areas.
Posted : 07/01/2011 6:42 pm
22/36 with a 11/34 cassette
Spin away from 2.5 mph to 28 mph
And I am old enough to be northwinds dad 🙂
Edit = to answer robdob - it requires a different technique - I go into the 22 at the bottom of any climb and use it as a low close ratio set - using 1-6 in granny
Posted : 07/01/2011 6:44 pm
22/36 on mine, works well for me
Posted : 07/01/2011 6:51 pm
I like 24/36. With 22/36 there's a big gap between gears.
Posted : 07/01/2011 6:52 pm
When I had double and bash it was on a 38lb bike that I only took on rides in the mountains so I felt I needed 22T 🙂
TJ - yeah I know what you are saying, I just felt I was being forced into the 22 very early heading into a climb and it felt like it robbed speed. Also when I was riding rocky sections I liked the 32/32 combo as the chain was tighter and didn't bounce around as much.
I don't have a problem with lack of high gears - I love a fast fireroad thrash and have always felt I have enough gears.
It will depend on your riding style and where you ride. I would try the 32/22 first if you already have the chainrings and only change if you think you need those higher ratios. I spent a lot of cash getting a 36 setup with the ring and bashguard and it turned out to be not for me.
Posted : 07/01/2011 7:00 pm
Thanks for the replys, think I'll give 36/26 a try as can always swap round some of the rings I've left in garage if I can't get on with it.
Posted : 07/01/2011 7:04 pm
I have 26/36t with 11-32t rear and it is absolutely perfect! To me anyway.
Posted : 07/01/2011 7:09 pm
22/32 and 11-32
low enough for what I ride. Don't miss the high end at all. Stay on the 32 for most stuff, drop to 22 for the real steep stuff.
Posted : 07/01/2011 7:29 pm
Dinnae be macho - get in that 22 at the bottom of every climb - gives you 6 or 7 close ratio low gears
Posted : 07/01/2011 7:37 pm
I have 26/36 with a 34 cassette and it works nicely and I find I need to change gear less for some reason. BTW I am no racing snake. Only disadvantage is when it gets to a very steep hill. One if I had a 22 granny I could get up with a lot of effort, one which was marginal for getting off and walking anyway.
Posted : 08/01/2011 9:02 am
36/22. 22 for the climbs using 2/3 of the cassette, 36 for everything else using the whole (11-32) cassette. Not been using it that long but after only a couple of rides it made more sense than 3x9. And the bash ring saved me from a very nasty injury recently!
Posted : 08/01/2011 1:01 pm
22/36 with 11-34 for me. Took me a little while to get used to shifting down more at the back when dropping into granny, but never looked back.
Posted : 08/01/2011 1:05 pm
Make sure you have plenty of room around the chainstay to accommodate the bigger rings. This can be a cause of chainsuck.
Posted : 08/01/2011 1:28 pm
As Buzz says - tried a 36 on my five, the chain came very close to the swing arm when changing gear. Put a 34 on, seams to be OK.
Posted : 08/01/2011 2:44 pm
