Hi what size of tape do i need for my hope enduro 23mm internal width rims do i need 25mm or 27mm
I'd say 25mm. And I'd recommend 25mm wide gorilla tape from B&Q. Amazing stuff, sticks so much easier than Stans and far cheaper - £2.97 for enough to do about 5 rims.
I did mine with 25mm Stan's. Was a bugger to use and I wish I'd have got the Gorilla Tape.
Just got tubeless valves, didn't use a rim strip.
great will try the gorilla tape looks thicker than the stans tape
I did mine with 25mm gorilla tape. Easy to apply just take your time and make sure there are no bubbles and the tape is centered. I used Stans valves though, because from experience they've been faultless.
Cheers guys I always put 2 layers on tape on before is it the same with gorilla tape
Up to you really, but I only needed one layer of the gorilla tape overlapped by about 3" across the valve hole.
Cheers guys appreciated
