Cant remember is it 8mm?
I think it is.
just hold one up against the valve?
Yep, 8mm.
8.5mm
Cheers guys.
Why would you want to do this? Presta works so nicely.
I realised I needed to do this the other week when I got two flats and realised my new rim was only for small valves and I had only packed the car-type... Oops.
8.5mm makes it a comfortable fit for the rubber-surrounded valves.
Use a vacuum while you drill to try to stop aluminum shards going into the rim cavity.
Pack Presta spares only; will always work.
pdV6 - Member
Pack Presta spares only; will always work.POSTED 22 SECONDS AGO # REPORT-POST
Oh how I laughed when I pulled a presta core from my last tube on the Selirk Merida, only to be told that I "should have drilled your rims mate, I could have gave you a tube"
as paulosaxo said. I was given about £15 in euros and Swiss Francs once when I donated a handy Presta I was carrying. The lucky recipients had Presta rims and a spare Schraeder tube. Ooops.
i wouldn't rush to enlarge the hole on any of my rims....
a larger hole means the rim is weaker.
+1 for presta. you can even get an adapter that allows you to use the pump at the petrol station on presta valves. costs naff all.
i wouldn't rush to enlarge the hole on any of my rims....a larger hole means the rim is weaker.
What like they do in the factory?
20 Euros for a Presta inner tube and use of track pump in Morzine was my best.
However if you would rather not have the option.....
It's for a non 'biker' friends bike and they struggle to use the fiddly presta, trying to make life a bit easier for them.
I much prefer Schralder valves but as I do own various different types of rim (mostly run tubeless) I now always carry presta spares with a little adapter sleeve on each so it can fit in a schralder hole without any slop if required...
I wouldn't tend ot drill my rims out, while it's unlikely to damage them, theres alwys the chance...
Do you have ANY idea how much metal is removed when drilling out a rim? It's tiny shavings, virtually nothing. I'd bet it's under 0.5g of alloy. I've been doing it for 20+ years with every presta rim I've ever bought. It is no problem at all, believe me! 🙂
Why anyone uses Presta valves on an MTB is beyond me anyway. weak, fiddly things that they are.....
While I agree I will still carry Presta spare tubes; Fortune favours the prepared as they say:
I can replace a Schralder tube with a presta tube, I can replace a presta tube with a presta tube, I can fix a karked UST setup on a presta drilled rim with a presta tube and I can fix a karked Schalder valved tubeless setup with a Presta tube, it covers all bases when out riding or on a group ride...
I'm with PP on this one, have done this on my mavic rims for ages, no problem with weakening them 🙄
The only ones I haven't is my 355s.......well not yet anyway just in case I do go tubeless eventually and the presta valves are more fiddly to pump up.
I can replace ALL our 7 bikes worth of wheels with a 26in schraeder tube because that's all I use. 🙂 if that won't fit someone else's bike then they should be better prepared! 🙂
