What parts do i nee...
[Closed] What parts do i need to convert solo air lyriks to coil?
is it a spring, top out spring and new top cap?
if i bought this would it be a case of take teh air assembly out and bolt this in, top oil up and done?
http://www.ebay.co.uk/itm/RockShox-UTurn-Spring-Assy-Lyrik-Med-Red-Standard-160mm-/320816382155?pt=UK_sportsleisure_cycling_bikeparts_SR&hash=item4ab22580cb
Posted : 21/12/2011 6:37 pm
I *think* i could buy whats linked and a top out spring. I can get the top out spring for £20, anyone have one laying around?
Posted : 21/12/2011 9:34 pm
Yup you need the spring, top out spring and top cap. Put plenty of grease on the spring before installing it, this stops it being noisy.
Posted : 21/12/2011 10:18 pm
 SOAP
Can this be done to Sektors soloAir's ?
Posted : 21/12/2011 11:29 pm
You also 'need' the plastic wrap that goes around the inside of the uppers. Or grease or shrink wrap but the correct part is pretty cheap.
Posted : 22/12/2011 6:41 am
got that cheers, need the top out spring assembly
Posted : 22/12/2011 7:19 am
Why?
Posted : 22/12/2011 8:25 am
because i like coil more than air tbh, always had coil bar one set of air revs which never felt right. My old coil lyriks felt a lot different in the initial bit of travel, where a mincer like me always seems to be - lol
If i set them so that the sag is right then they blow through the travel unless i put loads of LSC on which means that they are crap on small stuff. I i set them so that they are correct for my weight on the chart on the fork leg i don't get virtually any sag <10mm
Posted : 22/12/2011 8:51 am
