Clement xplor USH or Schwalbe G-ONE?
Currently using Clement but after 2500K i think the rear has seen better days.
Used for paved/graded roads in about 50/50 ratio.
Have used both and in my opinion the g-one is the better of the two.
Mine have lasted really well too.
*Which
I assume you have an outstanding IQ ๐
Which size G-One have you been using?
I thought my 30mm G-Ones didn't seem particularly hard wearing at all.
Rob Hilton - Member*Which
No sadly not. Also too lazy to re-read my posts before clicking send. ๐ณ
I was specifically thinking about the 40mm version. If anyone has experience of those it would be gratefully received.
I'm on the 35s. The originals, not the g-one whatever they are called now.
I have the s-ones on another bike in 30 and they are equally as good for more road biased work.
Continental sport contact 2. Compass bon jons
For the limited amount of non-tarmac riding I've done since fitting them, the 2.35" G-One Speeds have been good in terms of grip and rolling resistance.
I did get a rear puncture the other weekend on tarmac, while running it at ~40PSI with an SV19A tube, a few minutes from work. ~3mm gash in the central tread area (glass shard?).
Now running the rear much closer to the max rating of 50PSI.
http://www.planetx.co.uk/c/q/deals/the-alphabet-sale
Few gravel tyres in there at decent prices, when used with the 30% off code "PRATOZH"
I accidently bought a G-One All Round - a more knobbly version (it was in CRC's sale). Looks good for gravel. I do currently use the normal G-Ones tubeless for on-road as well as gravel - they're great, very fast rolling.
Hilton - Member
*WhichI assume you have an outstanding IQ
or an upstanding unicycle?
If your gravel bike / cx frame has the capacity for it, the Surly Knard 41c 120tpi version is a peach.
I'm not quite sure what a graded roads are but my 35mm g-ones are excellent for a mix of road and smoother trails, like towpaths/hardpack/fireroad-type stuff. Needs to be non-muddy and non-rocky though. For tougher terrain I swap to 40mm WTB Nanos.
[all tubeless]
I am using the G-One all-round - rolls superbly well on the road (not noticeably slower than road tyres) and goes well on the gravel at 40psi tubeless. well worth a punt.
