What is the chain l...
[Closed] What is the chain length rule for 1 x10...
What is the rule for setting chain length. Triple is chain on big & big +2 links, but what about 1x10.
Ta
Posted : 28/05/2013 10:05 pm
Assuming it's a hardtail, same rule and then check it on all cogs.
Posted : 28/05/2013 10:06 pm
Check out the piece on Bikeradar front page today. They are saying add 4 links.
Posted : 28/05/2013 10:08 pm
L = 2 (C) + (F/4 + R/4 + 1)
L = Chain length in inches. Round the final result to closest whole inch figure.
C = Chain stay length in inches, measure to closest 1/8”. Use chart below to find decimal measurement.
F= Number of teeth on largest front chainring.
R= Number of teeth on largest rear cog.
Posted : 28/05/2013 10:10 pm
There was a thing on (I think) Bikeradar today suggesting chain round ring & big sprocket plus four links, as this is what SRAM recommend for setting up XX1.
[i]Edit: not fast enough...[/i]
I just ran the chain over the biggest sprocket , over the chain ring through the mech and pulled the ends together until I thought the mech was stretched to it's limit, backed it off to give one link breathing space and that seems to have worked fine.
Posted : 28/05/2013 10:18 pm
