What is the best tu...
[Closed] What is the best tubeless tyre juice
Just run out of Stans. Is there any better out there?
Posted : 13/07/2010 10:26 am
Some people swear by Joe's, Stan's for me.
Posted : 13/07/2010 10:30 am
If Stans has been working for you then just stick with it. Personally I use JRA wheelmilk as it was the first one I bought so just get it out of habit.....oh and it has worked fine over the last 3 years.
Posted : 13/07/2010 10:31 am
I found wheel milk dried out stupidly fast, within a couple of weeks.
Posted : 13/07/2010 10:35 am
As njee20 said. I found Geax stuff to be the best by a long way. Too expnsive though. Bontrager is good in Bontrager tyres (despite what people say). Stuff I bought off Ebay was a bargain and worked, but it coated the tyre when it dried and took ages to peel off!
I'll probably go Stans next, as found that to be good, fairly long-lasting (unless I can find the Geax cheap again).
Posted : 13/07/2010 10:40 am
I've just moved to Joe's no flats after using wheel milk for years. Its nearly twice the price, but it definitely seals better and doesn't dry for ages, meaning less faffage topping up and it actually works out about the same spend as wheel milk in the longer term, since I'm using less as it doesn't dry for ages.
Posted : 13/07/2010 11:02 am
Joe's or Stan's seem to be as good as each other
JRA wheel milk [as others have said] just dries up stupidly fast
Posted : 13/07/2010 11:14 am
Whatever you do - don't get the Specialized AirLock sealant. I tried some as it was all my lbs had and I was impatient. It was cak.
It's like a snotty gunk that doesn't actually run around the tyre, just forms gloopy blobs inside (unless I got a really old bottle that was on the way out).....
Posted : 13/07/2010 11:44 am
Is it worth adding anything (like glitter) to the standard Joe's/Stan's mixes?
Posted : 13/07/2010 11:46 am
Effetto Caffe Latex is supposed to make it easier to seal up the tyre, which is a big plus for some people, but gets bad reports on how well it deals with punctures. Stans for me but then I've never tried anything else, Stans just works and is easy to find.
Posted : 13/07/2010 12:10 pm
Joes has already got some kind of particulate in it. I'm guessing this is why it seals better than wheel milk.
There's loads on this topic on MTBR, the consensus seemed to be that glitter didn't do any good.
I didn't think Joe's had any bits in it, as such I just got little jets of sealant spurting out and not actually sealing anything...
No-one tried the Caffe-Latex?
Edit: Too slow!
Posted : 13/07/2010 12:11 pm
Hmmm....going on the above maybe time to change from JRA stuff....even tho *jinx* I have not had any punctures with it.
Posted : 13/07/2010 12:43 pm
I only found the stuff in Joe's when I was decanting it out of a tyre I was changing.
Posted : 13/07/2010 12:46 pm
The LBS who built my bike used the Specialized sealant and the rear tyre in the beginning would loose pressure, however that soon settled down and my pressure seems to be staying constant, not added any air after the last couple of rides as I am experimenting to how low I can run them at before I get any burping.
Posted : 13/07/2010 1:10 pm
 Sam
I'm quite liking the caffelatex so far but it doesn't seem to deal well with larger punctures/cuts. Doesn't dry out too quickly though and definitely deals well with smaller punctures. Probably the most mess free system for getting stuff in the tyre as well.
Posted : 13/07/2010 1:23 pm
flippinheckler - Member
Would be interested to know what the consistency of this was like. The stuff I have got is of a similar consistency to the stuff that comes out of your nose when you have a real bunged up cold. It all clogged into blobs and didn't spread around the tyre......whereas the Stan's I swapped it for you can actually hear sloshing around.
Posted : 13/07/2010 1:34 pm
yeh Stumpy - maybe its gone off as that doesn't sound right ๐Ÿ™
Posted : 13/07/2010 1:37 pm
I had to change the front tyre around as the bike shop put it in the wrong ways so I lost some glup then and when the valve inserts came out when pumping them up as they weren't on tight enough, anyway it was white and very gluppy and was as you described in big globues, I assumed it needed to be like that to plug any punctures and seal, I also assumed that the motion of the wheels would separate and even out the substance, as I said all seems ok.
Posted : 13/07/2010 6:54 pm
[i]It all clogged into blobs and didn't spread around the tyre.[/i]
Some of the solutions react when in contact with water - eg. the Hutchinson's stuff. My mate used washing up liquid to seal the bead and the Hutchinson's gunk went all lumpy and had to be chucked.
Posted : 14/07/2010 11:50 am
flippinheckler - the stuff I got had a greeny-tinge to it. It was quite a way off white.
DezB - I did wonder if this was the case, so made sure that the tyre & rim was dry then I put the sealant in. I didn't need any washing-up liquid solution to get the beads to sit OK & seal so don't think that water was a problem.
Perhaps I got an old bottle of it......anyway, using Stan's now that seems to work well so will probably stick with that instead.
Posted : 14/07/2010 11:55 am
another vote for stans but as said elsewhere the micro-particles turn into an alien like blob when left for a long period of time.
Posted : 14/07/2010 1:36 pm
where is the best (cheapest) place to get Mr Stan's juice?
Posted : 14/07/2010 1:39 pm
Had bonty on one bike and stans on the other, Bonty seemed to dry out quicker. Both on Stans now, and quite happy with it!
Posted : 14/07/2010 1:43 pm
The Spesh sealant is quite greeny, snot coloured in fact, and has a similar consistency, as you say. It's rubbish!
I've got some Rapid Racer stuff which looks very similar, not got around to trying it yet, but I suspect it's not all that great!
Posted : 14/07/2010 1:52 pm
I've been using Joe's for about 6 months since I ran out of JRA wheel milk. The Joe's fluid does contains small granules however they tend to settle at the bottom of the bottle so you need to shake it vigorously before using.
When I took my tyres of to get my wheel trued I used a syringe to get all the fluid out to see how much was left. I used 120ml of fluid when I fitted the tyre and there was around 90ml of fluid left. There was also a thorn still stuck in the tyre but no loss of pressure.
Gets my vote ๐Ÿ™‚
Posted : 14/07/2010 4:53 pm
Can you guys get Slime in the UK? The original product was for use in inner-tubes, but they now make a product for use in tubeless. I have had it in the tires for almost 6 months and it is still fluid and no punctures.
I had used Stan's for the last few years with no issues except I recently swapped my tires for new ones and put my old ones on my wife's bike. It doesn't have tubeless rims, so had to use tubes. Getting the old, dried Stan's off the inside of the tires was a task.
Posted : 14/07/2010 6:18 pm
can you use slime meant for inner tubes in tubeless tyres?
Posted : 14/07/2010 6:30 pm
inner tube slime + modelling latex + windscreen washer fluid/water + glitter is the standard ghetto method. I usualyl do 33/33/33 and a small tub of glitter from tescos etc in when i did it.
Just got some stans stuff off ebay cheap and used that. Seems ace but not ridden it yet.
Posted : 14/07/2010 6:36 pm
I've ran Bontrager super juice, for a couple of years (No punctures!) just got some new tubeless nobby nic's that I am trying with Stan's no tubes.
Posted : 14/07/2010 7:03 pm
Somebody (dezb ?) suggested geax to me, so I use that. Seems good enough to me. Bit over a tenner for about 2-3 wheels worht
Posted : 14/07/2010 7:18 pm
Why would you need to do this to put inner tubes in?
Posted : 14/07/2010 7:52 pm
Not sure I really had to, but LBS mechanic recommended doing so---in retrospect, not sure what difference it would make unless leaving it in the tire might create wear/abrasion on the tube.
Singletracksurfer--I don't think the Slime for tubes works for tubeless--different formula/consistency, but I didn't try it.
Posted : 14/07/2010 8:07 pm
Scienceofficer - Member
"Why would you need to do this to put inner tubes in?"
I do this when I remove a tyre, not sure I have to, it's just quite satisfying to do :mrgreen: And must save entire grams.
Posted : 15/07/2010 12:28 am
