What is that horren...
[Closed] What is that horrendous click?
Old King headset but had new bearings when serviced a year ago by Saddleback in a new frame.
As I turn my bars through 70 degress in either direction there are 2 very loud and physically noticeable clicks, it's as noticeable as turning a key in a lock, what the hell is that???
Posted : 23/10/2017 11:26 am
Try taking the bearings out, rotating 90 degrees and re fitting. If the clicks now happen in different places it could be the bearings are worn.
Posted : 23/10/2017 12:05 pm
It's not something as infuriatingly obvious as the cables pulling and then flicking onto the frame is it?
70 degrees is a fair turn, so it could be something like that - I have chased similar noises around myself to find that they are nothing to do with what I thought......
Posted : 23/10/2017 12:27 pm
my first thought was cables rubbing in the stays, or against each other if you have a little cable tie holding them tidy.
Posted : 23/10/2017 12:35 pm
Your knees.
Posted : 23/10/2017 1:08 pm
cl looking like a d to anyone else on a mobile?
Posted : 23/10/2017 1:10 pm
probably my knees!
Posted : 23/10/2017 1:14 pm
You have a bat in the steerer tube, you wake it up each time you ridge the bars...
Posted : 23/10/2017 1:23 pm
It's the feeling through the bars that makes me think it's not cables, there's a very distinct click felt through the controls.
Posted : 23/10/2017 3:33 pm
Is it an old design King from before the aheadset patent expired?
Posted : 23/10/2017 3:37 pm
Your knees.
I remember reading here of someone who said he knew when his BB needed replacing because it drowned out the sound of his knees...
Posted : 23/10/2017 3:57 pm
Northwind - It could be, it's over 6 years old now.
When I backed off the pre-load the click has gone away but of course now there's play. Into the LBS this morning.
Posted : 24/10/2017 9:58 am
thered - Member
Have you had the fork out? The old (rubbish) design has a track record of scoring fork steerers which could definitely create your click.
Posted : 24/10/2017 6:21 pm
