What in god's ...
[Closed] What in god's name have I done to my forks?
I have a set of 5 year old Pike 454s. They're dual air, non u-turn and have been serviced just 6 months ago.
I was riding yesterday in't snow at Dalbeattie and there were strange things afoot- the fork wouild compress very easily, then bottom out horrendously, a real "clung" noise as it reached the bottom of the stroke. HOwever, it was bottoming out between 1-2" above where it normally would, so it bottomed at about 3" travel and then wouldn't return properly.
My SIDs that my mate was borrowing, unserviced for 2 years, behaved perfectly.
What've I broken? Is it new forks time?
Posted : 19/12/2010 8:32 pm
sounds like a seal has gone luke on the rebound circuit. Loco off here will sort you if you email him. If it is a seal its a home fix and piss to do. I could do it for you if you are around over xmas?
Posted : 19/12/2010 8:37 pm
Sounds like a seal to me too.
Bet it's dumped oil into the lower leg causing the early bottom out symptom.
Posted : 19/12/2010 8:40 pm
I'll be able to fix it myself I reckon, it's not like Rock Shox are complicated inside. So long's I've not snapped owt it'll be a good excuse to buy some circlip pliers.
As they say. Dead easy fix
Posted : 19/12/2010 8:43 pm
Definetely a seal,Sounds like the main piston seal
Posted : 19/12/2010 8:44 pm
Posted : 19/12/2010 8:46 pm
Ha HA like that
Posted : 19/12/2010 8:51 pm
Who's Loco ?
Posted : 19/12/2010 9:47 pm
fork tuning dude off here
Posted : 19/12/2010 9:49 pm
you got his email or contact info?
need my forks sorting.
Posted : 19/12/2010 9:54 pm
seach? Profile?
http://www.locotuning.co.uk
info@locotuning.co.uk
He talks a lot of sense
Posted : 19/12/2010 9:56 pm
cheers tj.
Posted : 19/12/2010 10:02 pm
What forks you on Blower? If it's RS just do 'em yourself, it's really really easy.
Posted : 19/12/2010 10:03 pm
Marzocchi 55's want em converted to coil,shite forks indeed.
Posted : 19/12/2010 10:07 pm
ive got some pikes 4 years old like yours still going strong. ๐Ÿ™‚
Posted : 19/12/2010 10:09 pm
Blower - Member
Try Elliot Campbell @ the bike shop in Innerleithen(not Alpine, `tother one) He used to work for Marz
Posted : 19/12/2010 10:54 pm
Ah, yeah, I had mine swapped to coil because they were rubbish. Again, a simple job but you'll need the bits.
Posted : 20/12/2010 3:00 am
 JCL
You've blown the dampers lower O-Ring causing hydrolock. Order oil, O-Ring kit and follow the rebuild instructions on the Sram site.
Posted : 20/12/2010 5:03 am
