Hi, finally got round to using my joystick light on thursday night, but when using it fitted on my specialized helmet, you cant get it angled right due to the positioning of the vents. You either have to have it pointing way to high or low, which sort of defeats the point of the helmet light if it dosent point where your looking! What helmet do you use with one?
i've used a Joystick in a Spec. helmet, i simply rotate the adjustable bracket so it's pointing in the right direction
you are using the bracket, you do know that the ball-and-socket bracket is rotatable?
Have you tried a vent off the centre line? The Joystick isn't heavy enough to pull your head over!
On my winter lid I have it side mounted.
fits my 661 bravo xc and fox flux fine, the joystick mount is one of the easiest to rotate, i'm surprised you can't get the appropriate angle.
use joystick on my Giro Xen withno problems, as others say rotate the ball and socket part to get it to angle where you want - simples.
anyone got a dead joystick I am wanting to have a play with one
to see if an upgrade is on the cards
This is probably a bit of a predictable response, but personally I'd say don't replace your helmet to work with a joystick- spend the money on a torch, fit that, sell the joystick, and have more money and IMO a better light.
Otherwise, it does fit perfectly on a Hex but I'm with the others, really surprised you can't get it to work as it is.
zip-tied onto/into a vent, decathlons standard helmet.
I'm a **** then! I didnt notice the ball'n'socket! as its very tight due to newness Doh!
