I've got an On One Enduro helmet and find it to be the most comfortable fit of any helmet I've had. The issue is, its really hot! I'm looking for something that will fit the same type of head shape as this does. Any recommendations?
I have both their Enduro and Croix helmets and both fit better than anything else I've ever ridden, so I would suggest if you like the Enduro then you will like the Croix.
I'm looking for something still MTB style. Just something that fits the same head shape and isn't as hot.
An On One Enduro helmet with holes drilled in it.
Very good
I wore my on-one enduro for the first time at the weekend in the FoD.
I rode up the push-up track a couple of times in 20+ degrees heat and was amazed by how comfortable the helmet was. I don’t think it was any hotter than my old Giro Feature.
Umm...sorry, that’s no help is it? 😆
I suppose it'll be winter before I know it so may just stick with it.
I suppose you could trim out the bug netting in there that the POC Trabec apparently doesn't have. That might improve airflow.
We've a new model too. With a rechargeable LED rear light.
https://www.planetx.co.uk/i/q/HEOOENDLED/on-one-enduro-led-mtb-helmet
Iv'e just bought a Bell 4Forty which is a lot more comfy than my previous Giro Hex.
Never tried an Enduro though.
I might give that new model ago, is it a similar fit like the previous one?
I fit the Croix quite well and my mtb helmet is a Giro Chronicle which fits even better (much nicer adjuster than the Croix - but then it should do as the helmet was £60 not £10) if that helps? Can’t say if it runs cooler than the On-One Enduro helmet as not tried one of those. It seems to stay cooler than my mate’s Troy Lee A1 and I’ve done some
Big / hot rides in it ok
