What Headset Do I N...
[Closed] What Headset Do I Need?
Jesus they make it complicated don't they....
So I have a 44mm internal diameter headtube, the manufacturer says it requires an inset headset, and I will be using a tapered fork.
A quick look at Chris Kings reveals quite a few options for inset headsets and I am struggling to see what the differences are?
Posted : 31/08/2017 3:05 pm
For a 44mm headtube and tapered steerer you'll need a ZS44/28.6 top and an EC44/40 lower. No idea what CK offer as I haven't looked at their headsets for years. With Hope you'd need a number 2 top and an H lower.
Posted : 31/08/2017 3:17 pm
Generally a 44mm head tube with a tapered steerer has an internal cup on top and external on the bottom to accommodate the taper...it's often written as something like:
IS44 (top cup)
ES44 (bottom cup)
At least most of the Nukeproof ones I've bought over the last few years have been listed like that.
If the streerer was a traditional straight 1 1/8 you'd need:
IS44 (top)
IS44 (bottom)
...as the lack of taper means the bottom cup can sit inside the head tube too.
Posted : 31/08/2017 3:18 pm
Check out the tech docs for headsets on Hope's website
Should make it clear
Posted : 31/08/2017 3:37 pm
This one, to be precise:
Helped me loads when rebuilding my son's bike
Posted : 31/08/2017 3:39 pm
 tang
I have a 44 headtube with a tapered fork. It takes a inset 7 chris king.
what he said - Inset 7.
Posted : 31/08/2017 3:59 pm
Thank you very much guys, much appreciated.
Posted : 31/08/2017 4:56 pm
