What front mech? Co...
[Closed] What front mech? Confused.com
I wanna upgrade front mech on my bike but I have no idea which mech I need to buy? Looking at buying XT. The bike is 3x9 but do I need top swing, conventional? What does this mean? :\
Posted : 12/06/2013 7:05 pm
Top swing is where the cage and pivots etc sit above the band.
Conventional swing is where the cage and pivots sit below the band.
Posted : 12/06/2013 8:18 pm
Thanks. What about direct mount?
Posted : 13/06/2013 7:23 am
Attaches directly to bolts on the frame, or to a plate held on by the bottom bracket.
Posted : 13/06/2013 7:28 am
Is the bike a hardtail or full suss? I learned the hard way that you need to buy front mech for the correct chainstay angle. I think the main options are 63-66 degrees and 66-69 degrees.
Hardtails usually have a smaller chainstay angle (angle between chanstay & seat tube). You can measure using a protractor (I downloaded a tiltmeter app on iphone and it measures the angle perfectly.
If you dont get the correct angle mech, you might not be able to get it to work on all 3 front rings. It affects the height of the cage compared to the chainrings and it can rub.
Unfortunately I bought a 66-69 degree front mech and now I cant use the big chainring. The cage hits the chainring when shifting over.
Posted : 13/06/2013 8:30 am
