What forks do I nee...
[Closed] What forks do I need?
[#2806849]
Building up a bike from scratch, I have a MTB frame, it's a Merida carbon race frame and need forks, I ride trails and some on road as well. What do you recommend, budget £150 for a good used set. And what size do I need?
Posted : 31/05/2011 4:49 pm
Same size as the frame.
80 or 100mm would probably be what the frame's designed for if it's a race model but worth checking - some newer ones may be 120mm
RS Reba's or SIDs or some Fox F100's would be a reasonable choice.
getting something light and with some compression damping control or a lockout for road riding.
you need to work out stack height of headset+ stem+ headtube + a few spacers if buying second hand to make sure the fork will fit the frame.
Posted : 31/05/2011 4:52 pm
RS Reba's or SIDs [s]or some Fox F100's[/s]* would be a reasonable choice.
+1 Reba and (new) SID's can be had from the classified for that amount of mone.
*Purely a personnal choice, I just wouldn't waste [b]my[/b] money on em.
Posted : 31/05/2011 5:34 pm
Forgot to say I will be using XTR V-Brakes on bike so forks need to accomodate those. Must admit I am confused by the sizes and what they mean. How do I know wether to get 80, 100, or 120mm? Should I base this on the size of the frame headtube?
Posted : 31/05/2011 5:48 pm
XTR V-Brake?
Errr older Reba's then... (not sure new SID came with V mounts and newer Reba's definitely don't)
Look at the manufacturers website, as to what it orignally came fitted with. Though you usually can get away with 80-120mm on a short travel (XC) frame, unless it has very steep angle.
Nope, but this, your headset, stem & spacers will make up the minimum steerer length on the fork you'll need to buy.
Posted : 31/05/2011 6:00 pm
youll want to stick to 100mm on that frame (ive got one)
its too steep with 80mm and its too slack with 120.
does the frame have V brake mounts .... mine doesnt !
Posted : 31/05/2011 6:24 pm
I'd say something like a Reba Team with V-brake bosses
Posted : 31/05/2011 6:46 pm
Yes my frame has v-brake mounts, when does your frame date from trail rat?
Posted : 31/05/2011 6:53 pm
