What exact headset ...
[Closed] What exact headset lower cup for new Orange five frame to fit straight 1 1/8 th
As title really, converting from old five to new tapered five but using existing 1 1/8th forks for the forseeable future, just want to know what pick and mix lower headset cup i need.
Cheers in advance
Posted : 10/05/2012 11:25 am
I'd suggest getting Hope's Tapered lower assembly, and using it with their step-down adaptor collar on your fork, this way allows you to just ditch the adaptor if you buy a tapered fork in the future. The only problem is that Hope are in the middle of a bearing supply issue at the moment, so they aren't available unless you can find a shop with stock.
Edit- we have stock of the direct fit step-down headsets, but they raise the front of the bike by about 10mm, and look fugly.
Posted : 10/05/2012 7:21 pm
Ah, ok so is there a non hope temporary option?
Posted : 10/05/2012 8:39 pm
Yep, any tapered lower should work with the Hope adaptor on your fork.
Posted : 10/05/2012 11:05 pm
