What do you use to ...
[Closed] What do you use to protect your chainstay?
I'm using a neoprene chainstay protector at the moment but thinking about fitting a bionicon. Not sure if the tie-wraps will work very well over the neoprene protector. Looking for alternative ideas - what does everyone else use?
Stu
Posted : 21/06/2013 12:03 pm
The biggest one of these they make: http://www.lezyne.com/en/chainstay-protector
(Meta5 has a rather thick swingarm)
Have previously used old innertubes though.
Posted : 21/06/2013 12:05 pm
Old innertube wrapped round and held on with zip ties.
Posted : 21/06/2013 12:06 pm
A clutch rear mech.
Seriously - I've taken the chainstay protection off both my bikes since I fitted clutch mechs as I just don't need it anymore...
Posted : 21/06/2013 12:08 pm
Frame wrap from bike-tart is very good if you apply it carefully and don't overlap it like mad.
Posted : 21/06/2013 12:12 pm
Clutch mech! No marks at all on my chainstay.
Will wrap it with an innertube at some point. Just to be safe.
Posted : 21/06/2013 12:13 pm
[url= http://m.screwfix.com/p/self-amalgamating-rubber-tape-black-19mm-x-10m/87717 ]This[/url] and it only sticks to itself and offers loads of protection and you remove it and there's no sticky residue left on the frame. Start behind chain ring and finish at cassette with a stealth zip tie. And cheap and neat to and you could probably put a lizard skin overt the top if you want.
Posted : 21/06/2013 12:19 pm
Heatshrink on the bike with a Horst link pivot and self amalgamating tape on the ones that don't.
using one of those neoprene guards at the moment but its a little on the short side so when i can be bothered i will go back to using the good old inner tube method...
Posted : 21/06/2013 12:21 pm
Personally, I've started using this -> http://www.screwfix.com/p/self-amalgamating-rubber-tape-black-19mm-x-10m/87717
One roll has done a couple of regular tubular chainstays on hardtails so far with roughly half width overlap and there's quite a bit left on the roll. Certainly enough to do at least one more chainstay, probably enough to do another two. Obviously you wouldn't get so many beefy swingarms out of a roll though...
Posted : 21/06/2013 12:26 pm
Zip-tied inner tube, tried and tested.
If you're on a clutch mech check you're not getting any heel rub before removing the protector. My winter shoes (which I wear quite a bit) would do some damage to an unprotected stay, which on a carbon frame seems like a recipe for disaster {also need a wee bit of protection on the non-drive side for this reason).
Posted : 21/06/2013 12:28 pm
Old inner tubes because I'm a tighwad. Seems to work really well and keeps the bike sounding quiet (my SX have the seat stays done as well).
Will be interesting to see how much of a real imporvement a clutch mech is when I get round to getting one.
Posted : 21/06/2013 12:29 pm
A section of drainpipe held on with 3 jubilee clips
SS FTW !!
Posted : 21/06/2013 12:31 pm
Another fan of the self-amalgamating tape from Screwfix.
Funnily enough my roll has just turned up today in the post 8)
Posted : 21/06/2013 12:34 pm
when my gran died, I had her stuffed and mounted by the local taxidermist.. She spent many happy years on our mantlepiece, but after an unfortunate incident with our pet Labrador Steven, we had to find a new home for her..
It was at this point that I removed most of the straw and sawdust that she was stuffed with and wrapped the perfectly preserved pelt around my chainstay.. held in place with a fine spun rope that I had made from her gossamar leg hair..
I now have a well protected stay and also I get the benefit of granny's smiling face beaming up at me every time I look back to see who I've just overtaken..
Posted : 21/06/2013 12:39 pm
Self amalgamating tape here as well, looks pretty neat and does a good job!
Posted : 21/06/2013 12:40 pm
the old inner tube and zip ties here
Posted : 21/06/2013 12:43 pm
I use method two from this - very neat and no zip ties. The guy is a bit hirsute and I wish he'd shut his legs, but very useful!! 🙂
Posted : 21/06/2013 12:45 pm
 core
A chainstay protector, off the shelf, they only a cost a few quid, don't know why it has to be any more complicated than that?
Posted : 21/06/2013 12:46 pm
I got some coloured silicon self amalgamating tape from the bay, red for the inbred and blue for the El Mar, colour match was pretty good to. No need for zip ties or owt.
Posted : 21/06/2013 12:50 pm
Because my amalgamation tape covers every mm of the chain stay so if the chain drops at the front you got cover.
Posted : 21/06/2013 12:52 pm
The fluffy half of self adhesive velcro works a treat
Posted : 21/06/2013 12:55 pm
For years I was using inner tubes, but my new frame came with a bolt on plastic protector which seems to be holding up ok. The underside has some scuffs from chain slap though, so hopefully my new Shadow Plus mech will help to reduce that happening in future.
Posted : 21/06/2013 1:03 pm
 Keva
bit of garden hosepipe sawn in half
Posted : 21/06/2013 1:07 pm
Zip ties and inner tube. Why spend money?
Posted : 21/06/2013 1:10 pm
I have a Bionicon on one of my bikes with a non-clutch mech. I took the velcro neoprene Lizard Skin off as I didn't want to cable tie the Bionicon over the Neoprene - I like to take the Neoprene off when cleaning the bike. So I wrapped some transparent Heli-tape round the chainstay. Works very well and pretty invisible. I do still get chain slap due to the non-clutch mech, but it is massively reduced.
Posted : 21/06/2013 1:11 pm
self amalgamating here too fantastic stuff
http://www.screwfix.com/p/self-amalgamating-rubber-tape-black-19mm-x-10m/87717 <
Posted : 21/06/2013 1:13 pm
I recently bought a cheap protector for about £4.50 came with a free copy of MBR which was nice!
Posted : 21/06/2013 1:31 pm
Another 1 for self alalgamating tape
Posted : 21/06/2013 2:17 pm
inner tube, they grow on trees it seems...
cheap & easy. the more expensive versions are just adverts and do a worse job due to having a wider profile
Posted : 21/06/2013 2:20 pm
Inner tube and black leccy tape. Way more tidy than even tie wraps and way cheaper than buying something.
Posted : 21/06/2013 2:59 pm
Neoprene thing that came free with MBUK. It's bliddy years old, a touch tatty (and it says MBUK on it!) but, it works....
Posted : 21/06/2013 5:13 pm
+1 for the inner tube and leccy tape. Super stealth on the BFe. Also wrap leccy tape around the bottom part of the seat stay just incase. Same principle applied to the white Mongoose but using white duck tape instead.
Posted : 21/06/2013 5:40 pm
Inner tube on one bike and the remains of a Panaracer tyre which lasted but a 1/2ml before ripping side out of it 🙄 Decided that it cost way too much to bin it after such a short rode it gets recycled for other stuff......Never bought another Panaracer since.....
Posted : 21/06/2013 9:58 pm
Self adhesive Velcro.
Posted : 21/06/2013 10:10 pm
Inner tube.
Posted : 21/06/2013 10:30 pm
The chainstay protector thingy that came with my frame. I did once use a strip of exploded Maxxis Minion on another bike. Was a bugger to slice up but it certainly kept the chainstay nice and smooth and looked quite pleasing.
Posted : 21/06/2013 10:37 pm
Csixx protector
Posted : 21/06/2013 11:12 pm
 blob
I use a velcro fastening neoprene chainstay protector and Bionicon V2 guide. Never had any problems with either- just attach the zip ties over the protector.
Posted : 22/06/2013 1:02 am
Thanks for all the suggestions everyone. Think I'll try the self-amalgamating tape for starters then ride the cr@p out of the bike to wear the mech out and get a clutch mech to replace it 😀
Prize for the best idea goes to yunki, though - really did laugh at that one!
Stu
Posted : 22/06/2013 9:49 am
