What do you use for...
[Closed] What do you use for pushing pistons back?
[#7093169]
Following the Great Tools thread, what do people use for pushing pistons back in? I've generally used a large-ish flat screwdeiver put appreciate it is not that good, and always wary opf damaging pistons/seals.
Bigdummy posted a pic of a Superstar tool with a big flat blade. What i reckon would be ideal though is a 2-bladed thing which works like reverse pliers to push both pistons back together. Would this work? / Does it exist?
Posted : 27/05/2015 2:52 pm
I tend to use a tyre lever though I do accept this may not be ideal either.
Posted : 27/05/2015 2:53 pm
couple of big plastic tyre levers. Don't press too hard and don't overthink it
Posted : 27/05/2015 2:55 pm
either a tyre lever or a ring spanner.
This is what Park think you need;
two wedges work well if a little fiddly
Posted : 27/05/2015 2:56 pm
Wheel out, leave the pads in, then with a flat head screwdriver push [i]on the back[/i] of one of the pads, then on the back of the other. Easy. 🙂
Posted : 27/05/2015 2:57 pm
stick a couple of worn out pads in, insett a screwdriver between them and then twist.
Posted : 27/05/2015 2:58 pm
 br
[i]Wheel out, leave the pads in, then with a flat head screwdriver push on the back of one of the pads, then on the back of the other. Easy. [/i]
+1
or when replacing pads:
[i]stick a couple of worn out pads in, insett a screwdriver between them and then twist. [/i]
Posted : 27/05/2015 3:07 pm
The handle end of an old bb remover, perfect size and it's got a rubbery coating on it.
Posted : 27/05/2015 3:09 pm
This^^
I have a couple of sets with all the brake material removed ,simples.
Posted : 27/05/2015 3:12 pm
maybe something like this would make wedges less fiddley
Posted : 27/05/2015 3:13 pm
on a similar note - what do people use for lubing pistons with?
I reckon most of my brake rubbing is down to calipers that have been adjusted properly, but one of the pistons deciding it's less keen on retracting than the other.
Posted : 27/05/2015 3:14 pm
Screwdriver's OK for basic two piston brakes but for the elite who have 4 piston brakes a shelf bracket works great
Posted : 27/05/2015 3:35 pm
Read about this ages ago on a motor bike forum and have used it on all my brakes ,it has been excellent ( even on Avids).
Put it on the side of the pistons when changing pads ( use a tiny paint brush).
Posted : 27/05/2015 3:37 pm
I lube Shimano pistons with Shimano brake fluid. It's quite slippery and you know it won't damage the seals.
Posted : 27/05/2015 3:38 pm
I've a particularly well shaped flat headed screwdriver that I use. Always have old pads to push against though
Posted : 27/05/2015 3:40 pm
+another
Posted : 27/05/2015 3:57 pm
Old worn out brake pads and a massive screw driver. A friend has used the bleeding block that come with Shimano brakes. . A couple of minutes on a belt sander turned it into a useful wedge sha
Pe
Posted : 27/05/2015 4:08 pm
I have one of these, works a treat
Posted : 27/05/2015 4:14 pm
plastic tyre lever works most of the time,
If not old pads method as above
Posted : 27/05/2015 5:03 pm
These for me
Posted : 27/05/2015 5:07 pm
2 old dinner knives pushed into the gaps and then rotate the wheel to push them in as wedges. Work brilliantly
 JAG
Ideally you want a bike-version of this car oriented tool....
[img] ?_v=5a94e708-b43a-47fc-b9d2-56110847a5a6[/img]
Posted : 27/05/2015 8:29 pm
if pad are in place then the Park piston press
if I am doing a proper brake service and pads are out, then its the ring end of a 10mm ring spanner
Posted : 27/05/2015 8:31 pm
I've just switched over to Shimano brakes and use a pedros tyre lever to push the pistons back, I will also try the old set of pads trick when I've worn a set out!
Posted : 27/05/2015 8:55 pm
