What do you Norther...
[Closed] What do you Northerners do to stop your bike freezing up!
I've just ridden Woodbury down yer in Devon, it's maybe -8C, we don't normally get it this cold. Frozen water in camelback. Frozen gears. I'm not used to it, does this happen oop North? Any tips for antifreezing my bike?
Posted : 03/02/2012 10:52 pm
blow-back in the camelback.
ride SS/hub gears. Or piss on your derraileur (if its not too cold to find your c0ck)
Posted : 03/02/2012 10:54 pm
Don't wash it, wipe it.
And ride SS rigid.
Posted : 03/02/2012 10:57 pm
Build yer bike oop norf and keep it in t'out 'Ouse along with coal for t'fire and yer prize whippet.
It'll then acclimatise to normal norfern temps lad
Posted : 03/02/2012 11:00 pm
if it has more than one gear you need to piss on it.
Posted : 03/02/2012 11:02 pm
 Pook
Nothing. Mine was frozen solid in the peak this week.
Posted : 03/02/2012 11:04 pm
Piss on it
Posted : 03/02/2012 11:06 pm
BTFU!
Posted : 03/02/2012 11:12 pm
Piss and cattle drinking trough or stream dunking - Gears, brakes, spds they dont work without it! In snow it is softer crashing though but it doesn't ever last too long.
Posted : 03/02/2012 11:21 pm
It dunt freeze if yer ont move yung en;) Get thee freak on lad an yull be rate.
Posted : 03/02/2012 11:25 pm
I just pee on mine. ๐Ÿ˜‰
Posted : 03/02/2012 11:26 pm
Had to de-ice my headtube with a hairdryer the other week. I assume that's not good.
 wors
We go to the pub instead ๐Ÿ™„
Posted : 03/02/2012 11:29 pm
wrap them up in a black pudding blanket ๐Ÿ™‚
Posted : 03/02/2012 11:31 pm
Don't change gear. Don't use your brakes (in the real north these freeze up too) and don't bother drinking your water. Simple really.
Posted : 03/02/2012 11:32 pm
Thanks all ๐Ÿ˜€
Posted : 03/02/2012 11:39 pm
Up here in Scotland it's not cold enough just now for frozen gears. Only -5 so far at night. And only a slight chance of snow tomorrow in the central belt. (Bit colder in the Highlands.)
Posted : 03/02/2012 11:54 pm
For the cables to freeze (unless it's stupendously cold) there needs to be water in them. So don't have any water in them.
Mechs like to fill with snow then freeze when you park, the solution for me is to administer several savage kicks to each mech. Bit technical.
Posted : 04/02/2012 12:22 am
Get yerself a pie n gravy n crack on with it lad!
Posted : 04/02/2012 12:24 am
SS & rigid. And use your foot on the tyre against the seat stays as a brake.
Posted : 04/02/2012 12:32 am
add vodka to your camelbak to stop it freezing ๐Ÿ˜€
Add gravy to chain lube to stop it freezing
Posted : 04/02/2012 8:50 am
They coat the bike in whippet fat and add meths to the camelbak.
Posted : 04/02/2012 8:53 am
